SOLVED Quick Tab Radio for GeDialog?
How do I create the 'quick tab radio' button in the gedialog?
What I found so far is only "radio buttons".
The c4d.gui.QuickTabCustomGui seems to be for actual tabs where you insert content and not like a button tab buttons.
You can see what I am going for here:
https://www.dropbox.com/s/5mik32wlhcwftcm/c4d204_quick_tab_radio_button_for_gedialog.jpg?dl=0
There is a relative thread about it here but its not really conclusive.
Is there a way around this?
Hi bentraje, the QuickTab Radio widget is obtained by still using the QuickTabCustomGui.
Find below a simplified snippet on how to get the result you'r looking for
ID_QUICKTABSRADIO_BAR = 1000  # ID for the quicktab customGui
class QuickTabRadio(c4d.gui.GeDialog):
    def __init__(self):
        self._quickTabRadio = None  # Stores the quicktab custom GUI
    def CreateLayout(self):
        # Creates a QuickTab Custom Gui
        bc = c4d.BaseContainer()
        bc.SetBool(c4d.QUICKTAB_SHOWSINGLE, True)
        bc.SetBool(c4d.QUICKTAB_NOMULTISELECT, True)
        self._quickTabRadio = self.AddCustomGui(ID_QUICKTABSRADIO_BAR, c4d.CUSTOMGUI_QUICKTAB, '',
                                           c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, bc)
        self._quickTabRadio.AppendString(100, "FK", False)
        self._quickTabRadio.AppendString(200, "IK", False)
    def Command (self, id, msg):
        if id == ID_QUICKTABSRADIO_BAR and self._quickTabRadio:
            if self._quickTabRadio.IsSelected(100):
                print "FK is selected"
            if self._quickTabRadio.IsSelected(200):
                print "IK is selected"
# Main function
    # Initializes the dialog
    diag = QuickTabRadio()
    # Opens the dialog in modal mode
    diag.Open(dlgtype=c4d.DLG_TYPE_MODAL, defaultw=100, defaulth=100)
# Execute main()
Hi @bentraje, following up with a discussion with @s_bach (thanks for watching over) you can also consider the following implementation:
        items = c4d.BaseContainer()
        items.SetString(1, "FK")
        items.SetString(2, "IK")
        bc.SetContainer(c4d.DESC_CYCLE, items)
        gadet = self.AddCustomGui(ID_QUICKTABSRADIO_BAR, 200000281, '',  c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, bc)
        # set initial value
        gadet.SetData(2)
    def Command(self, id, msg):
        # react to interaction
        if id == ID_QUICKTABSRADIO_BAR:
            value = msg[c4d.BFM_ACTION_VALUE]
            print(value)
        return c4d.gui.GeDialog.Command(self, id, msg)
@r_gigante
Thank you for the response and especially for the alternative code (first time to see a line with msg[c4d.BFM_ACTION_VALUE].
Both code works as expected.
