With the help of Pim Grooff's video, I have a GUI that generates buttons at run time.
My problem is it doesn't dynamic. How do I generate dynamic functions also to coincide with the dynamic buttons (along with their dynamic ids).
You can see the problem here: Button 1, 2, 3 works but not Button 4 and above. https://www.dropbox.com/s/svimsrbhx35egtk/c4d203_generate_dynamic_functions.mp4?dl=0
You can check the working code here:
import c4d from c4d import gui, plugins, bitmaps, utils, documents PLUGIN_ID = 1450011099 # Based from Pim Grooff's code # https://www.youtube.com/watch?v=jlQ2JBJvX5s def print_A(): return "1011 Button" def print_B(): return "1021 Button" def print_C(): return "1031 Button" class MyDialog(gui.GeDialog): def InitValues(self): self.newfieldindex = 0 self.button_commands = {1031: print_A(), 1032: print_B(), 1033: print_C()} return True def CreateLayout(self): self.SetTitle("Add/Remove Enable/Disable Dialog") self.GroupBegin(id=1002, flags=c4d.BFH_MASK, cols=2) self.AddButton(1021, c4d.BFV_MASK, initw=145, name="Add") self.AddButton(1022, c4d.BFV_MASK, initw=145, name="Remove") self.GroupEnd() self.GroupBegin(id=1030, flags=c4d.BFH_MASK, cols=1) self.GroupEnd() return True def Command (self, id ,msg): if (id==1021): self.LayoutFlushGroup(id=1030) self.newfieldindex += 1 if (self.newfieldindex < 0): self.newfieldindex = 0 for newid in range(1,self.newfieldindex+1): button_id = newid + 1030 fieldname = "Add-" + str(newid) self.AddButton(button_id, c4d.BFV_MASK, initw=145, name=fieldname) self.LayoutChanged(id=1030) return True if (id==1022): self.LayoutFlushGroup(id=1030) self.newfieldindex -= 1 if (self.newfieldindex < 0): self.newfieldindex = 0 for newid in range(1,self.newfieldindex+1): button_id = newid + 1030 fieldname = "Add-" + str(newid) self.AddButton(button_id, c4d.BFV_MASK, initw=145, name=fieldname) self.LayoutChanged(id=1030) return True if id in self.button_commands: print self.button_commands[id] return True class TestDialog(plugins.CommandData): dialog = None def Execute(self, doc): if self.dialog is None: self.dialog = MyDialog() return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID) def RestoreLayout(self, sec_ref): if self.dialog is None: self.dialog = MyDialog() return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref) if __name__ == "__main__": okyn = plugins.RegisterCommandPlugin(PLUGIN_ID, "Enable Disable Dynamic",0, None, "Enable Disable Dynamic", TestDialog()) if (okyn): print "Enable Disable Initialized"
I modified your code to dynamically react to IDs. (Btw, it's now a script for simple demonstration). edit: Actually, this is just shifting the problem. There's no way in python I know of to bind functions directly. (Wouldn't make sense on dynamically added Gadgets anyways, imho.)
import c4d from c4d import gui PLUGIN_ID = 1450011099 # Based from Pim Grooff's code # https://www.youtube.com/watch?v=jlQ2JBJvX5s def print_me(id): print id class MyDialog(gui.GeDialog): def InitValues(self): self.newfieldindex = 0 return True def CreateLayout(self): self.SetTitle("Add/Remove Enable/Disable Dialog") self.GroupBegin(id=1002, flags=c4d.BFH_MASK, cols=2) self.AddButton(1021, c4d.BFV_MASK, initw=145, name="Add") self.AddButton(1022, c4d.BFV_MASK, initw=145, name="Remove") self.GroupEnd() self.GroupBegin(id=1030, flags=c4d.BFH_MASK, cols=1) self.GroupEnd() return True def Command (self, id ,msg): if (id==1021): self.LayoutFlushGroup(id=1030) self.newfieldindex += 1 if (self.newfieldindex < 0): self.newfieldindex = 0 for newid in range(1,self.newfieldindex+1): button_id = newid + 1030 fieldname = "Add-" + str(newid) self.AddButton(button_id, c4d.BFV_MASK, initw=145, name=fieldname) self.LayoutChanged(id=1030) return True elif (id==1022): self.LayoutFlushGroup(id=1030) self.newfieldindex -= 1 if (self.newfieldindex < 0): self.newfieldindex = 0 for newid in range(1,self.newfieldindex+1): button_id = newid + 1030 fieldname = "Add-" + str(newid) self.AddButton(button_id, c4d.BFV_MASK, initw=145, name=fieldname) self.LayoutChanged(id=1030) return True else: print_me(id) return True if __name__ == "__main__": dlg = MyDialog() dlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID)
Gotcha. Thanks for the code and confirmation. For my code, it's not really a simple printing the ID. Each ID corresponds with a separate function/script. I guess I'll just store them in a separate list. Separate ID list and separate function script list. Then execute them by matching index.
