Have a function that creates a new instance of selected object (or, child of selected for now) - that works. Have functions that creates Cycle UserData on selected object, then populates with its children - that works. Next step I thought would be a breeze is creating the User Data "on" the newly created instance. Im pretty new to python so im sure theres a blatantly obvious way to do It I keep dancing around.
In my head, I think I want to pass the result of my createInstance function into my AddData function, but any means I try to do so gives me errors or no result. This version of my script is just from an arbitrary point so may be some other weirdness you could point out, just piecemealing at the moment.
C4D R20
import c4d from c4d import gui def createInstance(): # create Instance of Child of Selected Object if op is None: return obj = c4d.GeListNode.GetDown(op) inst = c4d.InstanceObject() inst.SetReferenceObject(obj) return obj c4d.EventAdd() def AddLongDataType(obj): # create User Data Container named Picker if obj is None: return bc = c4d.GetCustomDataTypeDefault(c4d.DTYPE_LONG) bc[c4d.DESC_NAME] = "Picker" obj.AddUserData(bc) c4d.EventAdd() def setQuickTab(obj, data): # change User Date container to type Cycle, populate with Children Names descid = data[0][0] bc = data[0][1] # Get the number of child objects parent = doc.GetActiveObject() count = len(parent.GetChildren()) H = c4d.GeListNode.GetChildren(parent) # Build new cycle options container dynamically cycle = c4d.BaseContainer() for i in range (0,count): child = H[i] n = c4d.BaseList2D.GetName(H[i]) cycle.SetData(i, n) bc[c4d.DESC_CYCLE] = cycle # Set modified description data container obj.SetUserDataContainer(descid, bc) # Notify Cinema 4D for changes c4d.EventAdd() def main(): AddLongDataType(obj) data = obj.GetUserDataContainer() setQuickTab(obj, data) doc.StartUndo() doc.InsertObject(inst) doc.AddUndo(c4d.UNDO_NEW, inst) doc.EndUndo() if __name__=='__main__': main()
Hello @esan ! I'm not entirely sure what the purpose of your script is, so I made changes to what you provided. You're probably already aware, but this script will only work with children of your selected object, not grandchildren.
The biggest changes were:
import c4d from c4d import gui def createInstance(obj): inst = c4d.BaseObject(c4d.Oinstance) # created Instance with Base Object inst[c4d.INSTANCEOBJECT_LINK] = obj # set Instance's reference link # set the name using the object passed to the function inst[c4d.ID_BASELIST_NAME] = "%s Instance"%obj[c4d.ID_BASELIST_NAME] return inst # return the Instance instance def AddLongDataType(obj): # create User Data Container named Picker if obj is None: return bc = c4d.GetCustomDataTypeDefault(c4d.DTYPE_LONG) bc[c4d.DESC_NAME] = "Picker" doc.AddUndo(c4d.UNDO_CHANGE, obj) obj.AddUserData(bc) c4d.EventAdd() def setQuickTab(obj, data): # change User Date container to type Cycle, populate with Children Names descid = data[0][0] bc = data[0][1] children = obj.GetChildren() # Build new cycle options container dynamically cycle = c4d.BaseContainer() for i,child in enumerate(children): cycle.SetData(i, child.GetName()) bc[c4d.DESC_CYCLE] = cycle doc.AddUndo(c4d.UNDO_CHANGE, obj) # Set modified description data container obj.SetUserDataContainer(descid, bc) def main(doc): obj = doc.GetActiveObject() if (obj == None): gui.MessageDialog("Please select an object.") return doc.StartUndo() AddLongDataType(obj) data = obj.GetUserDataContainer() setQuickTab(obj, data) inst = createInstance(obj) doc.InsertObject(inst) doc.AddUndo(c4d.UNDO_NEW, inst) doc.EndUndo() c4d.EventAdd() if __name__=='__main__': main(doc)
Hi @esan beside what @blastframe already say, I would like to add that while the next code is working
This is not how it's designed to work and how oop works in general. the usual way will be
op.GetDown()
Since it's a method internally python will assign the first parameter to self (Or the Object we are asking the child, so in your case, self is op.) so in your case this is similar but it may not be always the case and this could cause several issues, so please try to write proper OOP code.
For more information see Difference between Method and Function in Python
Another way to your initial problem is to return both the Children Object and the created instance object with
import c4d def createInstance(): # create Instance of Child of Selected Object if op is None: return obj = c4d.GeListNode.GetDown(op) inst = c4d.InstanceObject() inst.SetReferenceObject(obj) return obj, inst
Then when you call createInstance you can simply do the next things
child, instance = createInstance()
Hope it helps, Cheers, Maxime.
@m_adam @blastframe
Man your replies are a treasure trove of valuable info for me lol. I’ve found it tough finding focused info on c4d/python methods and the documentation lacks some context that makes it tough for beginners to implement, let alone “best practices”.
Ya I had a version where I was handling all the “get active” stuff in “main” but tied myself in knots in other ways so reverted back to a safe place haha.
Yes children are what I want, the purpose of the script is as follows:
With my job I have to re-create a lot of Ui and their components in C4D. I built an xPresso rig onto an Instance object that dynamically sets reference object based on defined hierarchy [so I want all of the children in the root]. Then manually create the user data to reflect that hierarchy, setting the reference object. That’s all well and good, from that point I can dup my “icon” instance (that’s referencing all the objects in my “icon” root) and just pick which icon it is from the user data list. Makes it easy/fast and clean creating large scenes of Ui.
But who wants to manually populate, and have to manually keep up with the user data fields to make sure they reflect children in your desired root. Didn’t see a way to automate that in xPresso so figured would be the perfect python exercise for me.
Select root, run script. Script creates your instance and integer cycle user data populated with the child hierarchy...and also creates the xPresso with node network, but I suspect I may find keeping all that functionality (selecting ref object for given instance) in python will be easier than figured out how to create the xPresso node network in python.
Again, thanks for the help!
@blastframe Just tried to run the code and it seems the original issue is still present. User Data is being added to the Selected Root instead of the newly created instance. Also its now instancing the root, instead of first child. That part I can fix, and hopefully have enough here to figure out the rest to get my original intent!
@blastframe Ok was able to retrofit your version to get what I wanted, a bit of guesswork in here, but got the result im after lol
import c4d from c4d import gui def createInstance(): obj = op.GetDown() inst = c4d.BaseObject(c4d.Oinstance) # created Instance with Base Object inst[c4d.INSTANCEOBJECT_LINK] = obj # set Instance's reference link # set the name using the object passed to the function inst[c4d.ID_BASELIST_NAME] = "%s Instance"%obj[c4d.ID_BASELIST_NAME] return inst # return the Instance instance def AddLongDataType(obj): # create User Data Container named Picker if obj is None: return bc = c4d.GetCustomDataTypeDefault(c4d.DTYPE_LONG) bc[c4d.DESC_NAME] = "Picker" doc.AddUndo(c4d.UNDO_CHANGE, obj) obj.AddUserData(bc) c4d.EventAdd() def setQuickTab(obj, inst, data): # change User Date container to type Cycle, populate with Children Names descid = data[0][0] bc = data[0][1] children = obj.GetChildren() # Build new cycle options container dynamically cycle = c4d.BaseContainer() for i,child in enumerate(children): cycle.SetData(i, child.GetName()) bc[c4d.DESC_CYCLE] = cycle doc.AddUndo(c4d.UNDO_CHANGE, obj) # Set modified description data container inst.SetUserDataContainer(descid, bc) def main(doc): obj = doc.GetActiveObject() if (obj == None): gui.MessageDialog("Please select the Root of the Assets you wish to Instance.") return doc.StartUndo() inst = createInstance() doc.InsertObject(inst) AddLongDataType(inst) data = inst.GetUserDataContainer() setQuickTab(obj, inst, data) doc.AddUndo(c4d.UNDO_NEW, inst) doc.EndUndo() c4d.EventAdd() if __name__=='__main__': main(doc)
