Solved Right Click Contextual Menu on a Button?
Is there a way I can have flyout/contextual menu when I right click button?
Currently, the default menu pops up when I do so.
You can see the illustration of the problem here:
https://www.dropbox.com/s/49rvo8w4qh77ozj/c4d202_rmb_contextual_menu_on_button.mp4?dl=0
Is there a direct way of doing this? That is a parameter of the AddButton element that allows such feature. There seems to be none in the documentation, but still want to confirm.
There is also a working code of RMB Contextual Menu on this thread. The problem is the RMB Contextual Menu is the same in all areas of the GeDialog.
I was thinking of just isolating the function in the area of button (i.e. indirect way).
If so, how do I determine the X,Y area of button relative to the dialog? Although of course, I'd prefer the direct way. hehehe
Thanks for looking at my problem
Hi @bentraje,
GeDialog.GetItemDim Can be used to retrieve x/y and size/height of a gadget. Of course, the dialog needs to be open, otherwise, you will get weird results.
So if you modify the code provided in Disable default Right-Click Menu of IsPositionInGuiArea with the next one is working as expected.
    def IsPositionOnGadget(self, gadgetId, x, y):
        # Be sure that the windows is opened,
        # in our case since we call it in BFM_INTERACTSTART it's ok
        buttonData = self.GetItemDim(gadgetId)
        if not buttonData["x"] < x < buttonData["x"] + buttonData["w"]:
            return False
        if not buttonData["y"] < y < buttonData["y"] + buttonData["h"]:
            return False
@m_adam
Works as expected! Thanks again for the sample code, makes everything clear.
