Calculate FPS tool?
I'm doing optimization of character Rigging recently, and encountered some problems:-
- Whether the Calculate FPS tool can be used as a standard tool to measure the performance of the scene, I did not find a description in the help document. Sometimes the test results will fluctuate greatly. Is there a more detailed description?
- Is there any other way to see the performance consumption of each specific part of the scene element? Xpresso provides an option to view the performance, but it is not enough.
I'm not sure if this section can ask non-code questions, please notify me if it is not allowed
hello,
It's always a bit tricky to measure performance. A lot of parameters have to be taken into account depending on how much precision you need.
We don't provide tool for that kind of analysis and using our API will not be really helpful.This section is about general programming and plugin discussions. The forum is still focused on using our API (so code related)
There could be a solution using our API but unfortunately, there's not.Cheers,
Manuel
hello,
Manuel
@m_magalhaes Thanks for your reply
