Unexpected Margin/Padding on AddCustomGui
My custom gui button has a width and height of 100 (i.e. should be square). The images are also in 100x100 dimension. But as you can see there are unwanted margin making it a portrait.
You can see the problem here:
https://www.dropbox.com/s/zo198h5b34igh3o/c4d191_unexpected_margin_on_custom_gui_button.jpg?dl=0This is the code with the
AddCustomGui
:sample_bmp = c4d.bitmaps.BaseBitmap() sample_bmp.InitWith(sample_img) bcBitmapButton = c4d.BaseContainer() bcBitmapButton[c4d.BITMAPBUTTON_BUTTON] = True buttonId = 2000 w = 100 h = 100 self.GroupBegin(id=9001, flags=c4d.BFH_SCALEFIT, groupflags = c4d.BFV_GRIDGROUP_EQUALCOLS | c4d.BFV_GRIDGROUP_EQUALROWS, cols=4, rows=4,initw=0, inith=0) for image in images: # iterates for every image in the image folder image_bmp = c4d.bitmaps.BaseBitmap() image_copy = os.path.join(image_path, image) image_bmp.InitWith(image_copy) # bitmapButton = self.AddCustomGui(buttonId, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_CENTER|c4d.BFV_CENTER, w, h, bcBitmapButton) bitmapButton = self.AddCustomGui(buttonId, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_FIT|c4d.BFV_TOP, w, h, bcBitmapButton) bitmapButton.SetImage(image_bmp, True) self.GroupEnd()
Thank you for looking at my problem
Hi @bentraje
CustomBitmapButton take by default the size of the icon and ignore the passed width/height. If you want to force the CustomBitmapButton you have to use BITMAPBUTTON_FORCE_SIZE with an Int32 value that represents the size of the icon.
Since it "ignore" the passed width/height you may also consider to use something else than BFH_FIT in a BFH_SCALEFIT group.
Thanks for the response.
I added a line with
bcBitmapButton[c4d.BITMAPBUTTON_FORCE_SIZE] = 100.00
and revised a line to
bitmapButton = self.AddCustomGui(buttonId, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFV_CENTER | c4d.BFV_CENTER , w, h,
However, it still gives an unwanted margin/padding but this time at the bottom.
https://www.dropbox.com/s/i6eb8ccszzc35ov/c4d191_unexpected_margin_on_custom_gui_button_02.jpg?dl=0
Hi @bentraje
Could you try to use
w = c4d.gui.SizePix(100) h = c4d.gui.SizePix(100)
For more information see GUI Layout Issues.
If not could you try to zip bmp + a complete working script?
Thanks in advance,
Almost close now. is there a way to totally remove the border space within the custom gui buttons?You can check it here:
https://www.dropbox.com/s/vs31t2flu51gnej/c4d191_unexpected_margin_on_custom_gui_button_03.jpg?dl=0I tried the
self.GroupSpace(0, 0)
but it has no effect.
I also triedself.GroupBorderSpace(0, 0, 0, 0)
but the whole button disappeared.Are there any other settings for spaces?
Here is working correctly, please share your code.
def CreateLayout(self): self.GroupBegin(10002, c4d.BFH_SCALE| c4d.BFV_SCALE, initw=50, inith=50) bcBitmapButton = c4d.BaseContainer() bcBitmapButton[c4d.BITMAPBUTTON_BUTTON] = True bcBitmapButton[c4d.BITMAPBUTTON_ICONID1] = c4d.Ocube bcBitmapButton[c4d.BITMAPBUTTON_BORDER] = c4d.BORDER_IN buttonId = 2000 w = c4d.gui.SizePix(100) h = c4d.gui.SizePix(100) self.GroupBegin(id=9001, flags=c4d.BFH_SCALEFIT, groupflags = c4d.BFV_GRIDGROUP_EQUALCOLS | c4d.BFV_GRIDGROUP_EQUALROWS, cols=4, rows=4,initw=0, inith=0) self.GroupSpace(0, 0) for imageId in xrange(10): bitmapButton = self.AddCustomGui(imageId, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_FIT|c4d.BFV_TOP, w, h, bcBitmapButton) self.GroupEnd() self.GroupEnd() return True
There's actually still space between buttons on your code.
Anyhow here is my working code for your reference. It's in archive file since it includes the images
https://www.dropbox.com/s/leb10klpvm4o8ps/c4d191_unexpected_margin_on_custom_gui_button.rar?dl=0
Hi @bentraje
thanks for the archive.Here my code in R21.115
In your code you call self.GroupSpace(0, 0) before the GroupBegin it has to be called just after the creation.
Which give me the next result
Oh I see. Thanks for pointing that out.
Thanks!
Sorry for reviving the thread but I just hit a snag on using the same code but for colored buttons. It doesn't respect the settings and gives an unnecessary margin even though I used the
c4d.gui.SizePix()
code.You can see the problem here:
https://www.dropbox.com/s/17yqc1i0puoau77/c4d191_unexpected_margin_on_custom_gui_button_04.jpg?dl=0You can see the working code here:
import c4d from c4d import bitmaps, documents, gui, plugins, threading, utils class ColorButton(object): def __init__(self): self.width = None self.height = None self.color = None self.btn_id = 3000 def create(self, dlg, w, h, color, btn_id): self.width = c4d.gui.SizePix(w) self.height = c4d.gui.SizePix(h) self.color = color bmp_color = c4d.bitmaps.BaseBitmap() bmp_color.Init(w, h) for y in xrange(w): for x in xrange(h): bmp_color.SetPixel(x, y, color[0], color[1], color[2]) bcBitmapButton = c4d.BaseContainer() bcBitmapButton[c4d.BITMAPBUTTON_BUTTON] = True bcBitmapButton[c4d.BITMAPBUTTON_BORDER] = c4d.BORDER_IN bmp_btn = dlg.AddCustomGui(btn_id, c4d.CUSTOMGUI_BITMAPBUTTON, "",c4d.BFH_FIT|c4d.BFV_TOP, w, h, bcBitmapButton) bmp_btn.SetImage(bmp_color, True) class MyDialog(c4d.gui.GeDialog): def CreateLayout(self): self.GroupBegin(10002, c4d.BFH_SCALE| c4d.BFV_SCALE, initw=50, inith=50) bcBitmapButton = c4d.BaseContainer() bcBitmapButton[c4d.BITMAPBUTTON_BUTTON] = True bcBitmapButton[c4d.BITMAPBUTTON_ICONID1] = c4d.Ocube bcBitmapButton[c4d.BITMAPBUTTON_BORDER] = c4d.BORDER_IN buttonId = 2000 w = c4d.gui.SizePix(100) h = c4d.gui.SizePix(100) self.GroupBegin(id=9001, flags=c4d.BFH_SCALEFIT, groupflags = c4d.BFV_GRIDGROUP_EQUALCOLS | c4d.BFV_GRIDGROUP_EQUALROWS, cols=4, rows=4,initw=0, inith=0) self.GroupSpace(0, 0) for imageId in xrange(10): bitmapButton = self.AddCustomGui(imageId, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_FIT|c4d.BFV_TOP, w, h, bcBitmapButton) # Red Button Through Class red_button = ColorButton() red_button.create(self, w=100,h=100,color=(255,0,0), btn_id=6000) self.GroupEnd() self.GroupEnd() return True if __name__ == "__main__": dlg = MyDialog() dlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC)
@bentraje said in Unexpected Margin/Padding on AddCustomGui:
c4d.gui.SizePix()
code.def create(self, dlg, w, h, color, btn_id): bmp_btn = dlg.AddCustomGui(btn_id, c4d.CUSTOMGUI_BITMAPBUTTON, "",c4d.BFH_FIT|c4d.BFV_TOP, w, h, bcBitmapButton) class MyDialog(c4d.gui.GeDialog): def CreateLayout(self): red_button = ColorButton() red_button.create(self, w=100,h=100,color=(255,0,0), btn_id=6000) return True
You don't use
c4d.gui.SizePix()
in your code and that's why it fails.Cheers,
You are right.
wasn't actually used.
Will close this thread now and crawl to my little cave of shame. lol
