On 01/05/2003 at 06:17, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.100 Platform: Language(s) : C.O.F.F.E.E ;
--------- **I can make a plugin registred in the "PlugIN"-Menu, but ** ow can I make a submenu ? **Another question: how do I copy an object and how can I put an already existing object in an other object as its child ? ** **Thx a lot, tamarilloDan **
On 01/05/2003 at 06:37, xxxxxxxx wrote:
1. You cannot specify a submenu directly. If your plugin is in a subfolder in the pluginsfolder of Cinema 4D and there is more than 1 plugin in this folder, Cinema 4D will show a subfolder automatically in the pluginsmenu. I don´t know if creating a subfolder in your pluginfolder will create a subfolder though. 2. Please refer to the COFFEE Documentation. obj->Remove(); obj->InsertUnder(parent); long time since I wrote in COFFEE but it should work that way. Best Samir
On 02/05/2003 at 01:19, xxxxxxxx wrote:
Yeah thats the right way. Thanks alot. I've got another problem, maybe u can help me ... var filename = GetGetRootFilename(); filename->RemoveLast(); filename->Add("my.exe"); GeExecuteFile( filename ); That works, but now I want to execute the my.exe with parameters (like "my.exe /helloworld") But by appending a " /helloworld" to the path, nothing happens. How can I execute the file with a parameter ? THX TamarilloDAN
