Hello everyone.
I want to get material from template file and apply it to project follow the sample material name. Can you show code C++, or Python? . It is sample video: https://www.youtube.com/watch?v=-zPQT0kRdPc&feature=youtu.be Thanks you very much.
as always, please make yourself familiar with how to post questions on this forum: Read Before Posting
I assume a "template file" is just a C4D-file that stores some materials?
You can load a C4D-File with LoadDocument(). Then you can copy the materials found in that loaded document into the active document. See BaseDocument Manual and BaseMaterial Manual.
import c4d import os def main(): # select the c4d file to load filename = c4d.storage.LoadDialog(type=c4d.FILESELECTTYPE_SCENES, title="Choose File.", flags=c4d.FILESELECT_LOAD, force_suffix="c4d") if filename is None: return # checks for c4d suffix name, suffix = os.path.splitext(filename) if suffix != ".c4d": raise RuntimeError('Invalid file selected.') # load the document (materials) loadedDoc = c4d.documents.LoadDocument(filename, c4d.SCENEFILTER_MATERIALS) if loadedDoc is None: raise RuntimeError('Could not load document.') # get all materials mat = loadedDoc.GetFirstMaterial() while mat is not None: # clone material clone = mat.GetClone() if clone is None: raise RuntimeError('Could not clone material.') # insert clone into the active document doc.InsertMaterial(clone) mat = mat.GetNext() c4d.EventAdd() if __name__=='__main__': main()
best wishes, Sebastian
Thanks s_bach very much.
