How to add Layers Shader that contain two layers (Bitmap shader and Hue/Saturation/Lightness effects) with HSL -100 %.
BaseMaterial *Mat = BaseMaterial::Alloc(Mmaterial); if (!Mat) return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION); BaseContainer *Data = Mat->GetDataInstance(); if (!Data) return true; BaseShader* bsXlayer = BaseShader::Alloc(Xlayer); if (!bsXlayer) return false; Data->SetLink(MATERIAL_ENVIRONMENT_SHADER, bsXlayer); Mat->InsertShader(bsXlayer);
Thanks.
Hi mfersaoui, thanks for reaching out us.
With regard to your question, whilst it's actually possible to query for the layers belonging to a certain Layer Shader, it's not possible to programmatically add new layers with the current API implementation.
Here you can find an old discussion on the argument.
Best, Riccardo
@r_gigante Hi Riccardo, Thank you, I will try to import my material from a scene file.
@r_gigante
I have another question, is it possible to edit the Blur Offset and Blur Scale of shader via c++?
"Blur Offset" and "Blur Scale" are parameters of the BaseShader class, so you should be able to access these parameters like any other parameter; if in doubt, they should be available in the shader's BaseContainer. See xbase.h.
@s_bach
Thank you.
