Prevent c4d from opening path passed in sys.argv
Hi!
I want to do pretty much what was proposed in this thread. That is passing a script via sys.argv.
It seems that Cinema is trying to load the file after I'm done with my stuff and since it doesn't recognize the filetype I get an error "Unrecognized file format!".
I tried consuming the path with sys.argv.remove(path), but that didn't really seem to do anything.
How can I prevent Cinema from attempting to open the path?Thanks!
Hi @Boony2000 unfortunately, Python can't consume/remove arguments.
But you could either add a variable so this way Cinema 4D will not try to load your file with something like
Cinema 4D.exe g_myvariable="filePath"
.Cheers,
.Cheers,
Hi Maxime!
Thanks for your answer.
Is there a way to directly get that variable in Cinema, or is it basically just modifying the string into something that isn't recognized by Cinema? For me it looks like I now have to seperate the string by finding the '=' or something like that. Is that what I have to do?
Thanks! I'll try that.
