i need the ressource syntax to add a field field to my interface.
as always, please use the Q&A system to mark your post as a question.
Do you mean a FieldList parameter in the description of a NodeData based plugin? The resource type is "FIELDLIST".
"FIELDLIST"
FIELDLIST EXAMPLE_FIELDLIST_PARAM {}
You find an example in the \resource\modules\objects\description\ofalloff_panel.res file.
best wishes, Sebastian
@s_bach said in Howto add a Field input to a python plugin:
FIELDLIST
works fine - i think i got an strange error before and trying CUSTOMFIELDLIST etc.
solved
