is there a way to change the order of reflection layers in a material? Or to create a new reflection layer at the end of the list, instead of always having it as first element?
Thanks & greetings, Frank
I think the short answer is: No. The longer answer is: Yes, but it is incredibly cumbersome (and dicey). The following script will reverse the order of the reflectance layers for the selected material.
import c4d # Main function def main(): """ """ # Just get the first active material and check if it is a reflection layer # supporting material. material_selection = doc.GetActiveMaterials() if (material_selection == [] or not material_selection[0].CheckType(c4d.Mmaterial)): return mat = material_selection[0] # Get all reflection layers and their data offset ids for that material reflection_layers = [mat.GetReflectionLayerIndex(lid) for lid in range(mat.GetReflectionLayerCount())] data_ids = [layer.GetDataID() for layer in reflection_layers] # Get a copy of the materials data container mat_data = mat.GetData() # I will just reverse the order of the reflection layers (or more precisely # the order of the data) to show the principle. Some sort of insertation # logic should be trivial to implement for you. for old_id, new_id in zip(data_ids, reversed(data_ids)): # The reflection layer data is stored in the container of the material # with a stride of 512, so for example reflection layer X goes from # SOME_ID to SOME_ID + 511. There are symbols for the stride IDs, check # https://tinyurl.com/yxvgmtmt for details. # A more safe approach would be to compile a list of that symbols, # rather than using that stride approach I use here. for i in range(512): # We just copy all data from our data container copy to the new # location, but there are data types we cannot handle in Python # within that stride, so we need this rather ugly construction. # I have no clue what that data is, things might break horribly. # !!! THIS MEANS WE EFFECTIVELY WON'T COPY ALL DATA AND MIGHT # GENERATE A CORRUPTED MATERIAL !!! try: mat[new_id + i] = mat_data[old_id + i] except: pass c4d.EventAdd() # Execute main() if __name__=='__main__': main()
Cheers zipit
Thanks, that idea crossed my mind, too. And thank you for even providing code! I was hoping there was a clean way to do that.
SDK team, any further insight about this? Is this possible in a clean way, or maybe in C++ ?
Cheers, Frank
from our point of view there's nothing to move things around. We have only this manual
I have to check to see if there's something hidden but got doubt about it. I'll be back with information if i find something
Cheers, Manuel
hello,
can we change this to solved ?
