I am able to get the center pivot of two objects but for some reason, it needs revision for three or more objects. You can see an illustration of the problem here: https://www.dropbox.com/s/u76v7zcbv8a38x4/c4d177_center_pivot_three_selected_object.jpg?dl=0
Here is the working code so far:
import c4d from c4d import gui # Main function` def main(): #Assuming there are three objects in the scene cube01 = doc.SearchObject('cube01') cube02 = doc.SearchObject('cube02') cube03 = doc.SearchObject('cube03') cube01_pos = cube01.GetMg().off cube02_pos = cube02.GetMg().off cube03_pos = cube03.GetMg().off # Getting the pivot of the two objects. Works as expected cube_dif = cube02_pos - cube01_pos cube01_02_pos = ((cube_dif/2) + cube01_pos) # Center Pivot # Getting the pivot of the three objects. cube_dif03 = cube01_02_pos - cube03_pos cube01_02_03_pos = ((cube_dif03/2) + cube01_02_pos) print cube01_02_03_pos #Does not match the pivot on the coordinate manager when all three objects are selected. # Execute main() if __name__=='__main__': main()
the term pivot is a bit ambiguous in this posting, since it refers to a point, while you are showing a frame, a transform matrix, Cinema's little coordinate system widget in your illustration (props by the way for including these).
The shared frame of N objects is just the arithmetic mean of the frames of these objects. Since you used the term pivot and things will get more complicated for averaging out also rotations (quaternions would be a solution) and scales, I will assume you are just after that the offset of that shared frame. Again in pseudo code:
pivot = sum([obj.GetMg().off for obj in my_objects]) * (1. / len(my_objects))
Cheers zipit
@zipit
Thanks for the response. I'm not really sure on the nomenclature but I am referring to the Red,Green,Blue arrows as the pivot.
Anyhow, for some reason your code does not match the pivot computed by the coordinate manager. You can see the illustration here: https://www.dropbox.com/s/tzlg3ry03e7tu5p/c4d177_center_pivot_three_selected_object02.jpg?dl=0
I am sorry, I wrote this posting without checking it in Cinema. It seemed pretty self explanatory to me, that this is the answer. I am not quite sure why it does not work, I will have to check this myself in Cinema (I do not have the time to do it right now). Possible solutions could be, that Cinema computes the geometric or harmonic mean (which would strike me as odd) or that I made an oopsie in my code (that I do not see right now).
PS: I pointed that pivot stuff out, because if the object frames (axis) are tilted (in respect to the world frame), then your shared frame will be titled too. Talking about a pivot implies you are not interested in that information. I just wanted to make sure, that this is the case.
Uhm, yep. For the pivot, I guess I'm also interested on the its "tiltedness". Basically, what the coordinate manager shows (the position and rotation). Sorry for not being clear.
I would just really like to call on the GetModelingAxis since it corresponds exactly with the coordinate manager but it only works on a selected object not document per se. In other words, it works only on one object but not on multiple objects.
GetModelingAxis
RE: I do not have the time to do it right now No worries. Thanks for the response. Have a great day ahead!
the axis displayed of a multi-selection is represented by a helper object.
One can acess that helper object using BaseDocument.GetHelperAxis().
See Axis and Plane.
best wishes, Sebastian
since @s_bach provided a much cleaner solution, I consider this solved and won't look for manual solution.
@s_bach Thanks for the response! Works as expected.
@zipit No worries. Will close this thread. I will probably revive this a year from now (lol). I have a feeling that Matrix will haunt me again in other aspects so this would be a nice exercise if that happens.
Thanks again!
