I got a plugin which returns, base on its settings a mesh or a spline. If i create an instance from my plugin using only GetVirtualObjects the Instance of my spline doesn't work.
so is there a way to use both in one plugin?
Hi @pyr first of all, in Cinema 4D there is no object that behaves like that. So it's not officially supported but you can get it to work.
With that's said I would like to ask for more information.
Note that few examples in the GitHub repository can help you:
Cheers, Maxime.
@pyr You can have both. GetVirtualObjects() is called first, and if you return nullptr GetContour() is called.
GetVirtualObjects()
GetContour()
But you need to register your object with OBJECT_GENERATOR | OBJECT_ISSPLINE.
@rsodre works flawless!
