When I try to Isolate, using c4d.documents.IsolateObjects(), a Cloner, I noticed the Effector is not 'Isolated / copied'. Also Copy and Paste into a new document (same as Isolate) does not 'Isolated / copy' the effector
Is there a way to fix this or should I use c4d.AliasTrans()?
-Pim
Hi Pim, thanks for reaching out us.
With regard to your question, the BaseDocument::IsolateObjects() method is not designed to transfer the items which are part of an in/exclude list like it's the case for the effectors in a MoGraph item. The method actually takes care of isolating objects that are part of the passed selection list, and their nested children, as well as the materials attached to such objects. It means that if you nest under a null object either the cloner and the effector you will end up in having the BaseDocument::IsolateObjects() method working as expect with effector being properly isolated and kept attached to the cloner.
If this is not feasible, then the best recommendation is to browse through the in/exclude list of the cloner, check for connected the effectors, add them to the C4DAtomArray used by the BaseDocument::IsolateObjects(). Upon isolation, the tests I've run so far, have confirmed that the link between effector and cloner are preserved so no need to re-link.
C4DAtomArray
Best, Riccardo
Yes, I already expected that. One comment, the same behavior occurs when you Copy and Paste a node into a new document.
