On 18/04/2003 at 15:11, xxxxxxxx wrote:
I was going to implement a simple flocking algorithm in COFFEE, but I need a way to store information about each child of an object. I would need to store velocities and things like that. I can't find anything that suggests this can be done, but I thought I'd throw it out here and see if anyone has some ideas.
On 19/06/2011 at 11:59, xxxxxxxx wrote:
I know this Thread is veeeery old, but for those who search for:
In a Coffeetag, you better use a struct:
struct MyStoredData { var velocity; var position; var acceleration; } var data = new(MyStoredData); main(doc, op) { data.velocity = ...
In a Plugin or Dialog for instance, you better define such variables as Class Attributes:
class MyPlugin : MenuPlugin { private: var velocity, acceleration, position; public: MyPlugin(); ...
(I hope the Syntax etc is right, its along time ago I did Coffee ..)
