Storing a part of the hierarchy
I want to store a part of the hierarchy in a external (hf) file.
For example, an object with multiple levels of children, materials, etc.I can put it in a new scene file and store that scene file, but perhaps there are other / better ways?
The ultimate goal is to store a part of the hierarchy in a tag plugin using node.write() and node.read().
hello,
you can use the function IsolateObjects than use SaveDocument or SaveProject
You can read it with LoadDocument to a temporary document inside memory.
Be careful, if you want to modify the active scene, you have to do it from the main thread otherwise you scene could be in an uncertain state leading to crash.
you can read information on how to deal with that case hereCheers,
Manuel
Thanks, again I learned another function (IsolateObjects).
If I use LoadDocument to store it in memory, how can I store that memory in the scene file, when the user saves the screen file?
I am going to use the tagplugin, so I guess that is all right?-Pim
hello,
what kind of functionality are you trying to introduce ? Using a tag doesn't look like the right place to do what you are trying to do.
Manuel
I will send you a pm with more details.
-Pim
you can send us an email at sdk_support@maxon.net
hello,
One possibility that i forgot to mention is MemoryFileStructure Manual
And ReadHyperFile or WriteHyperFile
You also have with a HyperFile the function WriteFilename
Hope this will help.
Manuel.
I want to store the node to be hidden in the scene file, so I guess hf wil not work for me.
In the other thread I learned to use IsolateObjects and that works now.So now I have a new doc in memory with the node I wanted to store.
I tried to put it in a subcontainer, but that did not work.
When reading back I just got None.import c4d PLUGIN_ID = 1234567 MyUniqueId = 456789 def main(): #retrieves the document baseContainer docBC = doc.GetDataInstance() sel = doc.GetSelection() # !!! only select the parent, not the children newDoc = c4d.documents.IsolateObjects(doc, sel) #create a sub-BaseContainer subBc = c4d.BaseContainer() subBc[1000] = "hello" subBc[2000] = newDoc # Add the container to the "main" Container docBC.SetContainer(MyUniqueId, subBc) # Updates the document container doc.SetData(docBC) # Print the values stored in our container. for cid, value in doc.GetDataInstance().GetContainer(MyUniqueId): print cid, value # Print Hello World print doc[MyUniqueId][1000], doc[MyUniqueId][2000] if __name__=='__main__': main()
Output:
1000 hello 2000 <c4d.documents.BaseDocument object called '' with ID 110059 at 0x00000173601BD370> hello <c4d.documents.BaseDocument object called '' with ID 110059 at 0x00000173601BD330>
Reading back the container:
import c4d PLUGIN_ID = 1234567 MyUniqueId = 456789 def main(): #retrieves the document baseContainer docBC = doc.GetDataInstance() # Print the values stored in our container. for cid, value in doc.GetDataInstance().GetContainer(MyUniqueId): print cid, value # Print Hello World print doc[MyUniqueId][1000], doc[MyUniqueId][2000] if __name__=='__main__': main()
Output:
1000 hello 2000 None hello None
the following line
will store a
BaseLink
(a reference, a pointer) tonewDoc
in your container, not the object itself. While Python's important syntax for bracket operators (__setitem__
,__getitem__
) usually is really convenient, in the case ofBaseContainers
it can obscure what you are actually doing. The verbose form of your call would be:subBc.SetLink(2000, newDoc)
Which works because
BaseDocument
is derived fromBaseList2D
and therefor also fromC4DAtom
(the typeBaseContainer.SetLink()
does expect as its second argument). However, when this link is not properly serialized on saving the document (which is impossible with your floating document), this link would be a null pointer when the document is loaded again. You cannot store aC4DAtom
in aBaseContainer
. At least I am not aware of a way to do so. You can only store references, which need to be kept alive in order to resolve.On a side note: This whole hijacking of the documents data container should not work in the first place, i.e. Cinema will just clear it out the container at your ID. I am a bit confused that you can actually read back your "hello" on a saved document.
zipit
One thing I forgot, which I already wanted to mention in your other threads, as it is a common technique to deal with similar problems in c4d. Are you aware that you can hide a
GeListNode
from the users view (so they won't show up in the Object Manager, the Material Manager, etc.) with theirNBIT
flags? This would be an easy way to store whatever you want to store. You won't believe all the hidden stuff that is floating around in your documents ;)For details check GeListNode.ChangeNBit().
zipit
@zipit, I got the code from another thread: https://plugincafe.maxon.net/topic/11802/writing-data-to-the-c4d-file/19
And if you changesubBc[2000] = "world!"
to
subBc[2000] = op
it also works!
I tried
and indeed it does not work. It returns a None on reading back the subcontainer after storing the file.
@zipit, yes I know that functionality (and use it often).
However, although it is hidden it still consumes cpu power.
We like to minimalize cpu power by converting a node using csto, hide the node and disabling generators and deformers in the node.
to
subBc[2000] = op
That is expected as op is also an
C4DAtom
.it also works!
I tried
The method
SetLink()
does not have a (boolean) return type. So this is to be expected too. I am not quite sure if you got my point, so here is a modified version of your first script - which you assume to be "working" as it printed back your document. I did modify it in such a way, that it does not work any more - I am really good at this specific task ;). I hope the code and the comments make more clear what I am trying to convey: That you are not storing your document, but a link to it.import c4d PLUGIN_ID = 1234567 MyUniqueId = 456789 def main(): #retrieves the document baseContainer docBC = doc.GetDataInstance() sel = doc.GetSelection() # !!! only select the parent, not the children newDoc = c4d.documents.IsolateObjects(doc, sel) #create a sub-BaseContainer subBc = c4d.BaseContainer() subBc[1000] = "hello" subBc[2000] = newDoc # Get the type of the ID we set print "ID 2000 is a link", subBc.GetType(2000) == c4d.DA_ALIASLINK # do the same thing in green. That SetLink() returns None # is expected as it has no return value (which is implictly # None in Python) subBc.SetLink(2000, newDoc) print "ID 2000 is a link", subBc.GetType(2000) == c4d.DA_ALIASLINK # Add the container to the "main" Container docBC.SetContainer(MyUniqueId, subBc) # Updates the document container doc.SetData(docBC) # Print the values stored in our container. for cid, value in doc.GetDataInstance().GetContainer(MyUniqueId): print cid, value print "\nDeleting newDoc...\n" # This part is a bit dodgy since Pythons garbage collector cannot # be trusted. But what I am trying to show is that you stored # a reference, not an object. For me it works here, but in some cases # an object can linger even after marking it for garbage collection. newDoc.Flush() del(newDoc) # Print the values stored in our container. for cid, value in doc.GetDataInstance().GetContainer(MyUniqueId): print cid, value if __name__=='__main__': main()
this should print out something like:
ID 2000 is a link True ID 2000 is a link True 1000 hello 2000 <c4d.documents.BaseDocument object called '' with ID 110059 at 0x00000135BC7F9030> Deleting newDoc... 1000 hello 2000 None >>>
zipit
Thanks for the explanation.
Two questions:
the line <c4d.documents.BaseDocument object called '' with ID 110059 at 0x00000135BC7F9030> always show a strange name ''? Why is it not showing the name of the document?
Back to the main questions, what to do, to store the node in scene file.
hello,
1 - what kind of strange name ?
2 -
you can store the data itself in the tag and than with the function read and write store them in the Scenefine
I'm using a file on the disk on this example but that should work with the HyperFile link provide by the read and write functions.Be aware that HyperFile.WriteMemory is storing byte sequences that will be platform dependent.
import c4d from c4d import gui # Welcome to the world of Python import os # Main function def main(): path = c4d.storage.LoadDialog(c4d.FILESELECTTYPE_SCENES, flags=c4d.FILESELECT_DIRECTORY) path = os.path.join(path, "prout.txt") # using a MemoryFileStructure to store a document mfs = c4d.storage.MemoryFileStruct() mfs.SetMemoryWriteMode() newdoc = c4d.documents.IsolateObjects(doc , [op]) # Save the document to the MemoryFileStructure c4d.documents.SaveDocument(newdoc, mfs, c4d.SAVEDOCUMENTFLAGS_NONE, c4d.FORMAT_C4DEXPORT) #Retrieve the data and store it somewhere, could be self.myData myData = mfs.GetData() #Save the data to a hyperfile myFile = c4d.storage.HyperFile() if not myFile.Open(0, path, c4d.FILEOPEN_WRITE, c4d.FILEDIALOG_NONE): raise RuntimeError("Failed to open the HyperFile in write mode.") # Store the size myFile.WriteInt32(myData[1]) # Store the data itself if myFile.WriteMemory(myData[0]) is False: raise ValueError("can't write the file") myFile.Close() # Read the data from the HF if not myFile.Open(0, path, c4d.FILEOPEN_READ, c4d.FILEDIALOG_NONE): raise RuntimeError("Failed to open the HyperFile in read mode.") size = myFile.ReadInt32() data = myFile.ReadMemory() myFile.Close() #Set the MFS mfs2 = c4d.storage.MemoryFileStruct() mfs2.SetMemoryReadMode(data,size) c4d.documents.MergeDocument(doc, mfs2, c4d.SCENEFILTER_OBJECTS) c4d.EventAdd() # Execute main() if __name__=='__main__': main()
Once again, be aware of where you are modifying the scene (on main thread and not elsewhere)
by the way, are you going to use c++ or python at the end ? (just for the tags of this thread)
Manuel
Great, thank you very much.
I am beginning to see the light.And yes, my fault, apparently I indicated it as c++, but I am doing it in Python.
About your warning.
My plan was to do it all in a tag plugin.
There I can have the interface, do the isolate and the read/write in a hf.
Or is it better to do it in a Object plugin?
@pim said in Storing a part of the hierarchy:
- the line <c4d.documents.BaseDocument object called '' with ID 110059 at 0x00000135BC7F9030> always show a strange name ''? Why is it not showing the name of the document?
Not quite sure what you do mean by that:
- The fact that the it prints the empty string for the document name is probably because you run the script on a unsaved document. This whole untitled_x.c4d stuff you see in c4d app is all smoke and daggers. An unsaved document will return the empty string for
GetName()
. - If you mean how objects are printed out, this is because of the way it is convention to implement
__repr__()
for an object. I found that obsession with memory addresses also always quite bizarre, but, hey, everyone is doing it ;)
zipit
Or is it better to do it in a Object plugin?Hi, it does not really matter what kind of
NodeData
you use, what @m_magalhaes meant, was that you should be careful with the threaded context of methods likeExecute()
inTagData
orGetVirtualObjects()
inObjectData
. When you execute your code from a method that is executed from the main thread, you are fine (e.g.NodeData.Message()
). You can always check there withc4d.threading.GeIsMainThread()
if you are in the main thread to be extra sure.Cheers
zipit
An ObjectData (generator) would be a bit better for that. But you are exploring possibilities, that's also the way to find new solutions / workflow.
About my warning it's just a reminder. You will have so sent message probably and use a MessageData to react to that message in order to do some action in the main thread.
Manuel
Thanks for all the support.
I will use all the knowledge gained and start testing.
I am sure, I will be back with more questions.-Pim
