Graphview OpenDialog id?
graphview OpenDialog(id,master),How to set this id to make the xpresso tag open in the default layout?
Thanks for any help!
Assuming with the default layout you mean the layout you get when clicking on an exprsso node, 1001148 (the id of the "XPresso Editor" plugin) seems to do the trick. I did not bother trying to find the symbol for that ID, because I am not sure if there is even one in Python.
import c4d """ All plugins that contain the substring "presso" in their name =============================================================================== Plugins with the ID 400009000: ------------------------------------------------------------------------------- <c4d.plugins.BasePlugin object called 'Start XPresso Calculation' with ID 4 at 0x00000181C3D07830> child nodes: [] =============================================================================== Plugins with the ID 1001145: ------------------------------------------------------------------------------- <c4d.plugins.BasePlugin object called 'XPresso Manager' with ID 4 at 0x00000181C3D07470> child nodes: [] =============================================================================== Plugins with the ID 1001138: ------------------------------------------------------------------------------- <c4d.plugins.BasePlugin object called 'XPresso Pool' with ID 4 at 0x00000181C3D07BB0> child nodes: [] =============================================================================== Plugins with the ID 1001148: ------------------------------------------------------------------------------- <c4d.plugins.BasePlugin object called 'XPresso Editor' with ID 21 at 0x00000181C3D07EB0> child nodes: [] =============================================================================== Plugins with the ID 1001149: ------------------------------------------------------------------------------- <c4d.plugins.BasePlugin object called 'XPresso' with ID 6 at 0x00000181C3D07F90> child nodes: [] """ def main(): # get the (first) expresso tag of the selected object tag = op.GetTag(c4d.Texpresso) if not tag: return # get the GvNodeMaster of that tag master = tag.GetNodeMaster() # open the graphview window for that master in the 'XPresso Editor' layout c4d.modules.graphview.OpenDialog(1001148, master) if __name__ == "__main__": main()
zipit
zipit
@zipit Thanks ,"id = 1001148" it work correctly
hello,
ID_TREEVIEW_PLUGIN 1001145
ID_EXPRESSION_PLUGIN 1001148
ID_OPERATORPOOL_PLUGIN 1001138
ID_EXPRESSION_TAG 1001149last one should be but it's not defined in python.
ID_CALCULATE_PLUGIN 400009000cheers,
Manuel
