Detect if document is being rendered in ModifyObject
Hello Plugincafe,
as the title implies I want to know wether the user is currently rendering the document => in the editor,
or in the picture viewer. I want to change settings of my modifier accordingly. (like the supdivision surface with supdivision editor/render).
What I have always done is check if the current document is the same as passed in ModifyObject (which works for picture viewer as the document is copied for rendering) but I don't know if this is the indended way of doing it or if there is somethihng else. In addition I want to do the same once the user renders in the editor, which my approach does not cover.
Is ther an "easy" way to accomplish this?Best Regards,
Florian
you are informed in
NodeData::Message()
of upcoming renderings viaMSG_MULTI_RENDERNOTIFICATION
. The message is accompanied byRenderNotificationData
which contain these flags.Cheers
zipit
Hey zipit,
thanks for the answer!Exactly what I needed!
Best Regards,
Florian
