Object materials won't show up in final render
Object materials won't show up in final render even though it shows up in the render view. bellow is my code:BaseObject* MyObject::GetVirtualObjects(BaseObject* op, HierarchyHelp* hh) { if (!op) return BaseObject::Alloc(Onull); Bool bIsDirty = op->CheckCache(hh) || op->IsDirty(DIRTYFLAGS_DATA); if (!bIsDirty) return op->GetCache(hh); BaseObject* container = BaseObject::Alloc(Onull); if (!container) return BaseObject::Alloc(Onull); BaseObject* cube = BaseObject::Alloc(Ocube); if (!cube) return container; // create the texture tag TextureTag* const textureTag = static_cast<TextureTag*>(cube->MakeTag(Ttexture)); if (textureTag == nullptr) return container; // apply material BaseDocument* doc = GetActiveDocument(); BaseMaterial* material = doc->SearchMaterial("mat_name"); if (!material) return container; textureTag->SetMaterial(material); cube->InsertUnder(container); container->Message(MSG_UPDATE); return domeContainer; } Bool MyObject::Message(GeListNode* node, Int32 type, void* data) { switch (type) { case (MSG_MENUPREPARE): { Material* const material = Material::Alloc(); if (material == nullptr) return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION); const Vector color(0.85, 0.85, 0.85); material->SetParameter(DescID(MATERIAL_COLOR_COLOR), color, DESCFLAGS_SET_0); material->SetParameter(DescID(MATERIAL_USE_REFLECTION), Bool(false), DESCFLAGS_SET_0); material->SetName("mat_name"); BaseDocument* doc = GetActiveDocument(); doc->InsertMaterial(material); break; } } return SUPER::Message(node, type, data); }
you use
GetActiveDocument()
in aNodeData
environment. You cannot do this, since nodes are also executed when their document is not the active document (while rendering for example - documents get cloned for rendering).Cheers
zipit
@zipit
I used the following and it is working.BaseDocument* doc = op->GetDocument();
Thank you.
For more information about it, please read the BaseDocument Manual.
