it seems the following function from the API is using an outdated default value
GeData* SearchPluginMenuResource(const maxon::String &identifier = "IDS_EDITOR_PLUGINS"_s)
An ID with the name "IDS_EDITOR_PLUGINS" is not used anymore since R21. It seems to be IDS_EDITOR_PIPELINE now. Hence, a menu that should appear after the "Extensions" menu now appears in the rightmost position, when using the default.
Cheers, Frank
HI, @fwilleke80 thanks for pointing it to us.
And I can only confirm the issue and inform you that I've open a bug report about it. Cheers, Maxime.
Thank you!
@m_adam The same probably applies to:
GeData* SearchPluginSubMenuResource(const maxon::String &identifier = "IDS_EDITOR_PLUGINS"_s, BaseContainer *bc = nullptr)
@fwilleke80 said in API: Bogus default value in SearchPluginMenuResource() declaration:
IDS_EDITOR_PLUGINS
Yes and also affect python.
