Reorder gradient knots by position
I'm searching a method to get gradient Knot by position not by index, the problem with gradient->GetKnot(i) is that when user change the knots position and knots order, the knot index stay the same for each knot.I had create the following python function to get knot by position and I sorted them from lower to higher knot position.
def GetKnotByPos(gradient, index): KnotDict = {} knotCount = gradient.GetKnotCount() for i in range(knotCount) : KnotDict[gradient.GetKnot(i)['pos']] = gradient.GetKnot(i) # dictionary’s keys select. Ks = list(KnotDict.keys()) Ks.sort() return KnotDict[Ks[index]]['col'] # Use gradient = op[c4d.MYOBJECT_GRADIENT] for index in range(gradient.GetKnotCount()): color = GetKnotByPos(gradient, index)
I'm searching how to do the same thing but using c++.
const Int32 knotCount = gradient->GetKnotCount(); for (Int32 i = 0; i < knotCount; i++) { GradientKnot knot = gradient->GetKnot(i); const Vector color = knot.col; result += String::VectorToString(color) + "\n"; }
you can use a maxon::BaseArray to store elements in a list. You can use maxon::BaseSort to define a class that is able to sort the elements of such a BaseArray.
In the case of GradientKnots, it could look like this:
// custom BaseSort based class class GradientSort : public maxon::BaseSort<GradientSort, maxon::BASESORTFLAGS::NONE> { public: static inline Bool LessThan(GradientKnot a, GradientKnot b) { return a.pos < b.pos; } }; const Int32 knotCount = gradient->GetKnotCount(); // prepare array maxon::BaseArray<GradientKnot> knots; knots.EnsureCapacity(knotCount) iferr_return; // fill array for (Int32 i = 0; i < knotCount; i++) { GradientKnot knot = gradient->GetKnot(i); knots.Append(knot) iferr_return; } // sort the elements stored in the array GradientSort sort; sort.Sort(knots); // check order for (GradientKnot& knot : knots) { DiagnosticOutput("Pos: @", knot.pos); }
best wishes,
Sebastian
best wishes,
Sebastian
