Hi all,
as we are managing loads of code that needs to stay backwards compatible with several releases, I came across the changes in String::GetCString() resp. maxon::StringInterface::GetCString(). The first accepts an argument of type STRINGENCODING to specify the desired encoding. The second one accepts a StringEncodingRef&.
STRINGENCODING
StringEncodingRef&
Is there some handy function which I can pass a STRINGENCODING value and get the corresponding StringEncodingRef in return? I can write myself with no problem, just wanted to know if there's something in the API already.
StringEncodingRef
Cheers, Frank
Hi Frank,
at the current time, we don't have any publicly-exposed method to achieve this. Some methods are available internally and I should check if they can safely exposed. Although I'll keep you updated on the topic, for the time being I consider it closed.
Best, Riccardo
Hi Frank, I've just been confirmed that the function will be exposed in the future.
