Modifier parameters change uppon scaling
I noticed that two of my parameters of my modifier change their values when I scale the modifier in the viewport.
I thought that it might be the Handles, but the only ones I have are from the Falloff/Field.
I tried changing the ids of those two parameters (both Realslider) but they do still change.
The only time I set/get the values for the parameters are in the Init function and in the ModifyObject function.I am at a complete loss here. Is there anything I could check that I may be doing?
Thanks in advance!
Best Regards,
Florian
float parameters using "meter" as a unit are automatically scaled, when the object is scaled.
You can disable this by setting
DESC_FORBID_SCALING
or "FORBID_SCALING" in the resource file.See Description Settings Manual.
best wishes,
Sebastian
DESC_FORBID_SCALING
best wishes,
Sebastian
Hello Sebastian,
thanks for this quick response!
I dind't know about this. But this solved my issue!Best Regards,
Florian
