Transparency of GeDialog?
Hi
Is there a way to control the transparency of the
GeDialog
when it is opened? Currently, it is opaque (i.e. a full gray where you can't see the background). I was planning to have an 80% transparency so I can see the background.The only transparency I can see in the documentation is the
SetTransparency
andGetTransparency
, but correct me if I'm wrong, it's only available to polygons.Is there a way around this?
Thank you
@bentraje said in Transparency of GeDialog?:
GeDialog
[...]To my knowledge there is currently no option to make a
GeDialog
partially or fully transparent. In the old forum there were quite a few threads on that subject.If you want some sort of non-rectangular shape for your menu, you will have to spawn multiple dialogs as @maxime did suggest in your initial question.
SetTransparency
is a method ofBaseDraw
meant for user defined polygon drawing operations to render these in a transparent style. You could technically also render your menu directly into a viewport via their associatedBaseDraw
, but your menu would then be restricted to viewports and also the whole approach would probably be a bit more technically challenging compared to aGeDialog
approach.Cheers
zipit
Thanks @zipit for the confirmation. No worries, it's only for cosmetics really.
Have a great weekend ahead! :)
hello,
Just to confirm what @zipit came with, it's not possible to handle GeDialog transparency.
Manuel
