I want to create an LAYOUTGROUP with two column and I want to add a full width SEPARATOR between certain elements. Here is my Description Resource code
GROUP ID_OBJECTPROPERTIES { GROUP { LAYOUTGROUP; COLUMNS 2; DEFAULT 1; GROUP { REAL MYOBJECT_WIDTH { UNIT METER; MIN 1.0; MAX 38000; MINSLIDER 0; MAXSLIDER 2000; STEP 1; } REAL MYOBJECT_HEIGHT { UNIT METER; MIN 0.0; MAX 38000; MINSLIDER 0; MAXSLIDER 2000; STEP 1; } REAL MYOBJECT_DEPTH { UNIT METER; MIN 1; MAX 100000; MINSLIDER 1; MAXSLIDER 3000; STEP 1; } SEPARATOR { LINE; } REAL MYOBJECT_FILLET_RADIUS { UNIT METER; MIN 0; MAX 100000; MINSLIDER 1; MAXSLIDER 700; STEP 0.1; } REAL MYOBJECT_THICKNESS { UNIT METER; MIN 0; MAX 10000; STEP 1; } SEPARATOR { LINE; } LONG MYOBJECT_AXIS { CYCLE { MYOBJECT_AXIS_XP; MYOBJECT_AXIS_XN; MYOBJECT_AXIS_ZP; MYOBJECT_AXIS_ZN; } } SEPARATOR { LINE; } BOOL MYOBJECT_SEEN_BY_CAMERA { } BOOL MYOBJECT_SEEN_BY_TRANSPARENCY { } BOOL MYOBJECT_SEEN_BY_REFLECTION { } } GROUP { LONG MYOBJECT_SEGMENTS_X { MIN 1; MAX 1000; } LONG MYOBJECT_SEGMENTS_Y { MIN 1; MAX 1000; } LONG MYOBJECT_SEGMENTS_Z { MIN 1; MAX 1000; } SEPARATOR { LINE; } LONG MYOBJECT_FILLET_SUB { MIN 1; MAX 1000; } } } }
And here is a screenshot of the result:
and here is an image of what I want to obtain as result (I want a full width separator line)
I tried with the following code, I obtain a full width separator but the first column elements doesn't have the same width
GROUP ID_OBJECTPROPERTIES { GROUP { LAYOUTGROUP; COLUMNS 2; DEFAULT 1; GROUP { REAL MYOBJECT_WIDTH { UNIT METER; MIN 1.0; MAX 38000; MINSLIDER 0; MAXSLIDER 2000; STEP 1; } REAL MYOBJECT_HEIGHT { UNIT METER; MIN 0.0; MAX 38000; MINSLIDER 0; MAXSLIDER 2000; STEP 1; } REAL MYOBJECT_DEPTH { UNIT METER; MIN 1; MAX 100000; MINSLIDER 1; MAXSLIDER 3000; STEP 1; } } GROUP { LONG MYOBJECT_SEGMENTS_X { MIN 1; MAX 1000; } LONG MYOBJECT_SEGMENTS_Y { MIN 1; MAX 1000; } LONG MYOBJECT_SEGMENTS_Z { MIN 1; MAX 1000; } } } SEPARATOR { LINE; } GROUP { LAYOUTGROUP; COLUMNS 2; DEFAULT 1; GROUP { REAL MYOBJECT_FILLET_RADIUS { UNIT METER; MIN 0; MAX 100000; MINSLIDER 1; MAXSLIDER 700; STEP 0.1; } REAL MYOBJECT_WALL_THICKNESS { UNIT METER; MIN 0; MAX 10000; STEP 1; } } GROUP { LONG MYOBJECT_FILLET_SUB { MIN 1; MAX 1000; } } } SEPARATOR { LINE; } LONG MYOBJECT_AXIS { CYCLE { MYOBJECT_AXIS_XP; MYOBJECT_AXIS_XN; MYOBJECT_AXIS_ZP; MYOBJECT_AXIS_ZN; } } SEPARATOR { LINE; } BOOL MYOBJECT_SEEN_BY_CAMERA { } BOOL MYOBJECT_SEEN_BY_TRANSPARENCY { } BOOL MYOBJECT_SEEN_BY_REFLECTION { } }
Result:
Thank you.
the trick is to use a dummy STATICTEXT element with the JOINENDSCALE flag. The example is taken from ddoc.res - the file for the project settings dialog. Rember you can (should) always use a text file search tool like Agent Ransack to peek into type, interface or smybol definitions to figure out how things are working.
STATICTEXT
JOINENDSCALE
ddoc.res
CONTAINER Ddoc { NAME Ddoc; GROUP DOCUMENT_GROUP_PROJECTSETTINGS { DEFAULT 1; COLUMNS 2; UNITSCALE DOCUMENT_DOCUNIT { ANIM OFF; } STATICTEXT { JOINENDSCALE; } BUTTON DOCUMENT_SCALEDOCUMENT {} STATICTEXT { } SEPARATOR { LINE; } STATICTEXT { JOINENDSCALE; } LONG DOCUMENT_FPS { ANIM OFF; MIN 1; MAX 2500; } BASETIME DOCUMENT_TIME { ANIM OFF; } BASETIME DOCUMENT_MINTIME { ANIM OFF; } BASETIME DOCUMENT_MAXTIME { ANIM OFF; } BASETIME DOCUMENT_LOOPMINTIME { ANIM OFF; } BASETIME DOCUMENT_LOOPMAXTIME { ANIM OFF; } SEPARATOR { LINE; } STATICTEXT { JOINENDSCALE; } REAL DOCUMENT_LOD { ANIM OFF; UNIT PERCENT; MIN 0.0; MAX 100.0; } BOOL DOCUMENT_RENDERLOD { ANIM OFF; } SEPARATOR { LINE; } STATICTEXT { JOINENDSCALE; } BOOL DOCUMENT_USEANIMATION { ANIM OFF; } BOOL DOCUMENT_USEEXPRESSIONS { ANIM OFF; } BOOL DOCUMENT_USEGENERATORS { ANIM OFF; } BOOL DOCUMENT_USEDEFORMERS { ANIM OFF; } BOOL DOCUMENT_USEMOTIONSYSTEM { ANIM OFF; } STATICTEXT { } SEPARATOR { LINE; } STATICTEXT { JOINENDSCALE; } LONG DOCUMENT_DEFAULTMATERIAL_TYPE { ALIGN_LEFT; ANIM OFF; CYCLE { DOCUMENT_DEFAULTMATERIAL_TYPE_WHITE; DOCUMENT_DEFAULTMATERIAL_TYPE_BLUE; DOCUMENT_DEFAULTMATERIAL_TYPE_USER; }} STATICTEXT { } COLOR DOCUMENT_DEFAULTMATERIAL_COLOR { ANIM OFF; FIT_H; } STATICTEXT { JOINENDSCALE; } SEPARATOR { LINE; } STATICTEXT { JOINENDSCALE; } LONG DOCUMENT_CLIPPING_PRESET { ALIGN_LEFT; ANIM OFF; PARENTCOLLAPSE; CYCLE { DOCUMENT_CLIPPING_PRESET_TINY; DOCUMENT_CLIPPING_PRESET_SMALL; DOCUMENT_CLIPPING_PRESET_MEDIUM; DOCUMENT_CLIPPING_PRESET_LARGE; DOCUMENT_CLIPPING_PRESET_HUGE; DOCUMENT_CLIPPING_PRESET_CUSTOM; } } STATICTEXT { } REAL DOCUMENT_CLIPPING_PRESET_NEAR { FIT_H; PARENTCOLLAPSE DOCUMENT_CLIPPING_PRESET; ANIM OFF; UNIT METER; MIN 0; } STATICTEXT { JOINENDSCALE; } REAL DOCUMENT_CLIPPING_PRESET_FAR { FIT_H; PARENTCOLLAPSE DOCUMENT_CLIPPING_PRESET; ANIM OFF; UNIT METER; MIN 0; } STATICTEXT { JOINENDSCALE; } SEPARATOR { LINE; } STATICTEXT { JOINENDSCALE; } BOOL DOCUMENT_LINEARWORKFLOW { ANIM OFF; } STATICTEXT { JOINENDSCALE; } LONG DOCUMENT_COLORPROFILE { PARENTCOLLAPSE; ANIM OFF; CYCLE { DOCUMENT_COLORPROFILE_SRGB; DOCUMENT_COLORPROFILE_LINEAR; DOCUMENT_COLORPROFILE_DISABLED; }} STATICTEXT { } GROUP { STRING DOCUMENT_COLORINFO { PARENTCOLLAPSE DOCUMENT_COLORPROFILE; ANIM OFF; CUSTOMGUI MULTISTRING; WORDWRAP; READONLY; } } SEPARATOR { LINE; } STATICTEXT { JOINENDSCALE; } SEPARATOR { LINE; } STATICTEXT { JOINENDSCALE; } GROUP { COLUMNS 1; BOOL DOCUMENT_CONVERT_BXDF_TO_COLORCHANNEL { ANIM OFF; } } STATICTEXT { JOINENDSCALE; } SEPARATOR { LINE; } STATICTEXT { JOINENDSCALE; } GROUP { COLUMNS 2; BUTTON DOCUMENT_PRESET_COMMAND_LOAD { } BUTTON DOCUMENT_PRESET_COMMAND_SAVE { } } STATICTEXT { JOINENDSCALE; } } GROUP DOCUMENT_INFO_GROUP1 { SCALE_V; STRING DOCUMENT_INFO_AUTHOR { ANIM OFF; } STRING DOCUMENT_INFO_COPYRIGHT { ANIM OFF; CUSTOMGUI MULTISTRING; SCALE_V; WORDWRAP; } STRING DOCUMENT_INFO_README { ANIM OFF; CUSTOMGUI MULTISTRING; SCALE_V; WORDWRAP; } STATICTEXT DOCUMENT_INFO_FILEFORMAT { ANIM OFF; BORDER; } STATICTEXT DOCUMENT_INFO_FILEVERSION { ANIM OFF; BORDER; } STATICTEXT DOCUMENT_INFO_PRGCREATOR_STRING { ANIM OFF; BORDER; } STRING DOCUMENT_INFO_PRGCREATOR_NAME { HIDDEN; ANIM OFF; } LONG DOCUMENT_INFO_PRGCREATOR_ID { HIDDEN; ANIM OFF; } STATICTEXT DOCUMENT_INFO_DATECREATED_STRING { ANIM OFF; BORDER; } STATICTEXT DOCUMENT_INFO_PRGWRITER_STRING { ANIM OFF; BORDER; } STRING DOCUMENT_INFO_PRGWRITER_NAME { HIDDEN; ANIM OFF; } LONG DOCUMENT_INFO_PRGWRITER_ID { HIDDEN; ANIM OFF; } STATICTEXT DOCUMENT_INFO_DATESAVED_STRING { ANIM OFF; BORDER; } FILENAME DOCUMENT_PATH { HIDDEN; READONLY; ANIM OFF; DIRECTORY; } FILENAME DOCUMENT_NAME { HIDDEN; READONLY; ANIM OFF; } FILENAME DOCUMENT_FILEPATH { READONLY; ANIM OFF; } BITMAPBUTTON DOCUMENT_PREVIEW_IMAGE { SCALE_H; BORDER; } LONG DOCUMENT_PREVIEW_COMMAND { SCALE_H; ANIM OFF; CUSTOMGUI CYCLEBUTTON; CYCLE { DOCUMENT_PREVIEW_COMMAND_AUTO; DOCUMENT_PREVIEW_COMMAND_PASTE; DOCUMENT_PREVIEW_COMMAND_FROMEDITOR; DOCUMENT_PREVIEW_COMMAND_LOAD; } } } GROUP DOCUMENT_INFO_GROUP2 { //STRING DOCUMENT_INFO_PREVIEW { ANIM OFF; } } }
Cheers zipit
@zipit said in LAYOUTGROUP Description Resource:
I'm searching this solution for long time, thank you so much!!!
