Initially thought that only Redshift (or any third party) Revised Node Editor API is not available. But I check the documentation, there is actually no Node Editor.
So basically, I still can't script the creation of material shaders and nodes inside the node editor even though it is a native material (i.e. Prorender or Standard or Physical)?
Is this assessment correct?
your assessment is correct. The Cinema 4D R21 SDK does not provide an API to edit node materials.
best wishes, Sebastian
@s_bach
Ok. Thanks for being upfront.
@s_bach said in Node Editor API for R21?:
Hello, your assessment is correct. The Cinema 4D R21 SDK does not provide an API to edit node materials. best wishes, Sebastian
Are there possibly any functions for traversing existing node graphs?
/Filip
The Cinema 4D R21 SDK does not provide an API to edit or access node materials; this includes traversing the internal node graph.
@s_bach OK, thanks!
