Just checked the R21 documentation and introduces a new import maxon line. Does this mean the import c4d will be deprecated in the future and slowly replaced by the import maxon?
import maxon
hello @bentraje
Don't forget to mark your thread as question and mark it solved after
The core of cinema4D have been rewrite. (started some years ago now) and more and more of the old code is replaced by the new API.
So you have what we call "classic API" that is c4d and the modules below, and the Maxon API that is the new one.
import c4d -> Classic API import maxon -> Maxon API
That's the same with c++, the Maxon API will replace the Classic API in the future, but we don't know how much time it will take and how much time the classic API will remain before being removed.
For sure, you should use, as much as possible, the Maxon API.
Cheers Manuel
Gotcha. Thanks for the confirmation.
How usable is the Maxon API (import maxon) at the moment? Can it select an object and modify its parameter?
I'm sorry I can't find any MaxonAPI example codes. Most the example scripts in the Github are still in Classic API (import API)?
the new maxon module is new to me too, but here are some of my impressions:
maxon
C++
volume
CustomdataTags\MeshAttributes
VariableTags
CustomdataTags
Cheers zipit
Well, to answer you @zipit, i'm not going to say "this all follows a bigger plan"
I understand that from an external point of view the Maxon API is "just" a concept but it's not we are using it every days, more and more will be bring to you. Don't forget, in Cinema 4D, you have what is exposed in the API and what's behind the curtain.
I'm not going to enter into details but the Maxon API will also help us to bring the C++ functionalities really faster than before. So the python will be closer than what we have in C++
MeshAttributes allow you to store any kind of information on points. Before you were limited to c4d Datatype. It's not only about replacing old stuff, it's giving the developers the same tool we are using and a lot more possibilities.
There's not too much examples in python for now because we didn't wrote them yet.
Keep asking questions, we will write examples, improve documentation etc..
@bentraje It look obvious but in the documentation the Maxon API is what's on the right.
So not too much for now but, as with the c++ questions, we will more and more answer with Maxon API code.
Cheers Manuel.
@zipit
It seems like so (i.e. you won't need the maxon module unless using the volume framework)
@m_magalhaes I check the documentation previously, but I have problem looking for stuff. For instance, I want the equivalent of doc.SearchObject() in Maxon API or modiying parameters Cube[c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_X] = 10
doc.SearchObject()
Is this possible in Maxon API currently?
@m_magalhaes said in Import C4D vs Import Maxon:
Hi, Well, to answer you @zipit, i'm not going to say "this all follows a bigger plan" I understand that from an external point of view the Maxon API is "just" a concept but it's not we are using it every days, more and more will be bring to you. Don't forget, in Cinema 4D, you have what is exposed in the API and what's behind the curtain.
I think there was a misunderstanding. I did not (want to) say that the new API is 'just a concept'. I am at least somewhat aware of its role on the C++ side of things. I was just trying to convey that it is a more fundamental change than just adding the new functionality X and that what is now exposed to us in the maxon module mostly deals with these more fundamental paradigm changes. I was (trying to) directly answer one of the questions of the OP: If he has to worry about the new API on day-2-day tasks like selecting an object. My answer was: He doesn't
Sorry for my misunderstood @zipit (my french side you know ^^)
@bentraje don't try too much to search for equivalent for now.
I'm not talking about python but about that Classic/Maxon API :
For example, BaseContainer is used almost everywhere in Cinema4D. It's not something you can migrate to DataDictionary like nothing ^^ But, in some case, you can use DataDictionary for parts of your codes but you still need BaseContainer to access object's parameters.
Some of part of the classic API are using part of the maxon API GetImageSettingsDictionary return a maxon.DataDictionary or the same with GetAutoWeightDictionary
We are moving toward the Maxon API, it's going to take time. Don't be surprise and if you have question, just ask.
Cheers, Manuel
@zipit @m_magalhaes
Yes, zipit was correct on my concern: If he has to worry about the new API on day-2-day tasks like selecting an object
Guess, I don't have to for now.
Thanks for the clarification.
