Browsing Plugin Paths
Hello, I'm looking for a way to get the filepaths from the Preferences -> Plugins -> Search Paths menu. I have a circumstance where one plugin needs to know where another plugin is installed so I want to be able to check those remote paths, but I can't figure out how to access the parameter.
GetWorldContainer() doesn't seem to contain this parameter but it does others, so I'm not sure where to go from here.
Dan
hello,
thanks @zipit for the answer.
@d_schmidt, please, don't forget to mark your thread as a question and mark it as solved once it is. That help us :)
Instead of getting the preferences, you can use GetModulePaths. It returns all module paths configured through g_modulePath, g_additionalModulePath and user preferences. Including Corelibs and Plugins default directories.
You can have information on Application manual
// Returns all module paths configured through g_modulePath, g_additionalModulePath and user preferences. // include corelibs and plugins default directory. const maxon::BaseArray<maxon::Url> myPluginPaths = maxon::Application::GetModulePaths() iferr_return; for (auto plugPath : myPluginPaths) DiagnosticOutput("plugins path @", plugPath);
If you do know the plugin ID, you can also use this kind of code.
const maxon::Int32 plugin_ID = 1038235; BasePlugin* myPlugin = FindPlugin(plugin_ID, PLUGINTYPE::ANY); if (myPlugin == nullptr) return maxon::NullptrError(MAXON_SOURCE_LOCATION); const Filename myPluginPath = myPlugin->GetFilename(); const maxon::String directory = myPluginPath.GetDirectory().GetString(); DiagnosticOutput("directory of plugin @ is @", plugin_ID, directory);
Manuel
preference data is often even for native c4d features implemented as a
PreferenceData
plugin. You have to access that plugin then. To get there you can drag and drop description elements into the python command line, delete the__getitem__()
part (the stuff in brackets), and get the__repr__
of the object. With that you can figure out the plugin ID of the correspondingBasePlugin
and then access your values.For your case as a script example:
import c4d from c4d import plugins # Welcome to the world of Python def main(): # Search for a plugin ID with a known str __repr__ of a BasePlugin. We got from the console: # Drag and drop: Plugins[c4d.PREF_PLUGINS_PATHS] # >>> Plugins # <c4d.BaseList2D object called 'Plugins/Plugins' with ID 35 at 0x0000028FE8157A50> pid, op = None, plugins.GetFirstPlugin() while op: if 'Plugins/Plugins' in str(op): pid = op.GetID() break op = op.GetNext() print "pid:", pid # Use that ID op = plugins.FindPlugin(pid) if op: print op[c4d.PREF_PLUGINS_PATHS] # we know the enum from the console # Execute main() if __name__=='__main__': main()
You can use then that Plugin ID in cpp to do the last part (
Use that ID
) there.Cheers,
zipit
hello,
Manuel
Thank you both for the replies! Between both of them I have exactly what I need, thanks.
