Unusual Dynamic Inputs from GeDialog
I am trying to create a dialog that list objects in the scene with specific parameters. However, it somehow skips some rows unexpectedly. You can see an illustration of the problem here:
https://www.dropbox.com/s/hppgdpa3ghpsr9t/c4d135_unusual_dynamic_inputs.mp4?dl=0Is there a way around this?
You can check the working code here. The glitch happens in the line
for idx, object in enumerate(self.objectsList)
block:import c4d import os from c4d import gui, plugins, bitmaps, utils, documents PLUGIN_ID = 1811321 class MyDialog(gui.GeDialog): def __init__(self): # Be sure that we have the object list before building the UI # as InitValues is called after CreateLayout() self.objectsList = [] self.GetAllObjects() self.object_count = len(self.objectsList) def InitValues(self): # Use to Init and in Case of an Update needed. self.objectsList = [] self.GetAllObjects() self.object_count = len(self.objectsList) self.Update() return True def GetNextObject(self, op ): # use a non-recursive method to iterate the hierarchy # https://developers.maxon.net/?p=596 # allow to not hit the recursive stack limit. if not op: return None if op.GetDown(): return op.GetDown() while not op.GetNext() and op.GetUp(): op = op.GetUp() return op.GetNext() def GetAllObjects(self): doc = c4d.documents.GetActiveDocument() op = doc.GetFirstObject() self.objectsList = [] while op: self.objectsList.append(op) op = self.GetNextObject(op) def Update(self): # NEW CODE if self.object_count == 0: self.LayoutFlushGroup(1001) self.AddStaticText(0, c4d.BFH_CENTER, name="There are no objects in the scene") self.LayoutChanged(1001) if self.object_count > 0 : self.LayoutFlushGroup(1001) self.AddStaticText(0, 1, name="Name") self.AddStaticText(0, 0, name="Enable") self.AddStaticText(0, 0, name="Xray") self.AddSeparatorV(0) self.AddSeparatorV(0) self.AddSeparatorV(0) for idx, object in enumerate(self.objectsList): # where the glitch happens text_ID = (idx) * 1 enable_ID = (idx) * 2 xray_ID = (idx) * 3 self.AddEditText(text_ID, flags=c4d.BFH_LEFT, initw=200, editflags=c4d.EDITTEXT_HELPTEXT) self.AddCheckbox(enable_ID, flags=c4d.BFH_LEFT, initw=20, inith=10, name="Enable") self.AddCheckbox(xray_ID, flags=c4d.BFH_LEFT, initw=20, inith=10, name="Xray") self.SetString(text_ID, value=object.GetName()) self.SetInt32(enable_ID, value=object[c4d.ID_BASEOBJECT_GENERATOR_FLAG]) self.SetInt32(xray_ID, value=object[c4d.ID_BASEOBJECT_XRAY]) self.LayoutChanged(1001) def CreateLayout(self): print "nombre d'objet ", self.object_count self.GroupBegin(id=1001, flags=c4d.BFH_FIT, cols=3, rows=20, title="Rigging") self.GroupEnd() self.Update() return True def Command(self, id, msg): return True def CoreMessage(self, id, msg): if id == c4d.EVMSG_CHANGE: self.InitValues() return True class MyMenuPlugin(plugins.CommandData): dialog = None def Execute(self, doc): if self.dialog is None: self.dialog = MyDialog() return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=200, defaulth=150, xpos=-1, ypos=-1) if __name__ == "__main__": plugins.RegisterCommandPlugin(PLUGIN_ID, "test_dynamic_update",0, None, "test_dynamic_update", MyMenuPlugin())
@bentraje said in Unusual Dynamic Inputs from GeDialog:
You actually overwrite the data yourself.
idx at 0, so text_ID = 0, enable_ID = 0, xray_ID = 0
idx at 1, so text_ID = 1, enable_ID = 2, xray_ID = 3
idx at 2, so text_ID = 2, enable_ID = 4, xray_ID = 6
idx at 3, so text_ID = 3, enable_ID = 6, xray_ID = 9
etc...So please rethink your algorithm, the easier way is to have a base ID for all tree and add the current index like
text_ID = 100000 + idx
enable_ID = 200000 + idx
xray_ID = 300000 + idx
Thanks for the help. Works as expected.
Have a great day ahead!
