Saving pointers to BaseObjects for use between scene updates
I'm trying to build a list of objects pulled in from the scene and save that list for use in future scene updates.
This seems to work fairly well using
maxon::BaseArray<BaseObject *>
. I can use a combination of GetDirty()/GetHDirty() to keep track of hierarchy changes and invalidate the list when the dirty count is increased. However, if I do an undo in the scene, GetDirty()/GetHDirty() do not update and yet the object pointers are changed- leading to an immediate crash when I try to access them again.What is the proper way of keeping internal references to objects within the scene? At first glance, BaseLink looks like it might have been the way to go, but I can't seen to figure that one out since creating a new BaseLink with
BaseLink::Alloc()
and subsequently callingmyBaseLink->SetLink(obj)
followed byBaseObject *myObject = static_cast<BaseObject *>(myBaseLink->GetLink(doc))
just causes an immediate segmentation fault.How can I store objects in a safe manner so that I can access them later on (assuming they're still part of the scene)?
-CMPX
Hi cmpxchg8b and thanks for reaching out us.
With regard to your issue, it's explicitly discouraged, as written in the C++ API documentation, to store
BaseObject
pointers and to use them for further operations especially when object creation/deletion and undo processes steps takes place.It's instead recommended using the
BaseLink
which provides a convenient and reliable way to refer toBaseList2D
elements in a scene.BaseLink
principles and use are well explained here.Finally, the code below doesn't show the segmentation fault you've mentioned.
maxon::Result<void> Check(BaseDocument *doc) { // check for passed parameter if (!doc) return maxon::IllegalArgumentError(MAXON_SOURCE_LOCATION); // get the active BaseObject BaseObject* obj = doc->GetActiveObject(); if (!obj) return maxon::OK; // print the object's name DiagnosticOutput ("Object [@]", maxon::String(obj->GetName())); // allocate a BaseLink BaseLink *link = BaseLink::Alloc(); if (!link) return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION); // connect to the object link->SetLink(obj); // access the BaseObject referred by the link BaseObject* const linkedObj = static_cast<BaseObject*>(link->GetLink(doc)); // print the referred object's name DiagnosticOutput ("Linked Object [@]", maxon::String(linkedObj->GetName())); // assert returned names are equal DebugAssert(obj->GetName() == linkedObj->GetName()); return maxon::OK; }
Looking forward further feedback, give best.
Riccardo
BaseObject
BaseLink
Riccardo
Greetings!
Thanks for the reply.
I kinda goofed up- apparently my objects were being improperly deconstructed before I was trying to use them, which was causing the BaseLink to get deleted and crash on subsequent access. BaseLink does indeed work fine and solves my problem. Sorry for the confusion!
-CMPX
