Hi all,
I was wondering if there is a method or function that I can use to export the selected objects and its materials to a new document? I couldn't find one that worked...
I'm sure that I can come up with some code that can can clone the objects and materials separately and then connected them in the new document.
Thank you in advance!
Found it!
c4d.documents.IsolateObjects(doc, t_objects)
A helper routine to copy the objects t_objects of document doc to a new document (returned). All materials associated are also copied over and the links are corrected.
Parameters: doc (c4d.documents.BaseDocument) – The document that contains the objects in t_objects. t_objects (List[c4d.BaseObject]) – The objects to isolate. Return type: c4d.documents.BaseDocument
Returns: The document containing the isolated objects.
Thank you all !
