I've marked your thread as a question, feel free to mark it as solved when you think it is, see this thread for information : Q&A New Functionality.
I have to make things clear here. Your screenshot show you are using a generator while you code add object to the document. You can't modify the scene in a generator. It's forbidden. For this kind of scenario, (add object to a scene and tracks and keys) it's better to use a script.
a few links to have information, even if they are about c++ there are lot of information there.
You have to create a track for each vector (position, rotation, scale) and for each vector's component (X,Y,Z)
I've create a script example for only the position X parameter. Feel free to create a function for that and add other track (Y, Z and rotation, scale etc)
# Welcome to the world of Python
# Main function
# Creates the object in memory
obj = c4d.BaseObject(c4d.Ocube)
# Creates the track in memory. Defined by it's DESCID
trY = c4d.CTrack(obj, c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_POSITION, c4d.DTYPE_VECTOR, 0), c4d.DescLevel(c4d.VECTOR_Y, c4d.DTYPE_REAL, 0)))
# Gets Curves for the track
curveY = trY.GetCurve()
# Retrieves the current time
keyTime = c4d.BaseTime(0)
# Adds the keys
added = curveY.AddKey(keyTime)
# Checks for error
if added is None:
raise TypeError("cannont create a key")
# Retrieves the inserted key
firstKey = added["key"]
kIndex = added["nidx"]
# Sets the value of the key
firstKey.SetValue(curveY, 0)
# Changes it's interpolation
firstKey.SetInterpolation(curveY,c4d.CINTERPOLATION_SPLINE)
# Sets the key to default status AutoTangent etc...
curveY.SetKeyDefault(doc,kIndex)
# Adds another key
keyTime = c4d.BaseTime(10, doc.GetFps())
if added is None:
secondKey = added["key"]
secondKey.SetValue(curveY, 100)
secondKey.SetInterpolation(curveY, c4d.CINTERPOLATION_SPLINE)
curveY.SetKeyDefault(doc, kIndex)
# Inserts track to the object
obj.InsertTrackSorted(trY)
# Inserts the object in document
doc.InsertObject(obj)
# Pushes an update event to Cinema 4D
# Execute main()
if __name__=='__main__':
Manuel
