i code to create a group of cylinders in C4D python,why no response?
I am a beginner in C4D python, i want to create a group of cylinders in python,This is my original script, it is simple but wrong, Thank you if you can solve my problem
import c4d def create_object(x): position = c4d.Vector(x, 0, 0) a = c4d.BaseObject(c4d.Ocube) a.SetAbsPos(position) return a def main(): for i in range(1,1000,100): create_object(i) '''
it should be a line array group of cylinders,the distance of each is 100,but
No response,i am so sad~
Hi ilad, thanks for reaching out us and welcome to our community
With regard to your issue, there are two main things to note:
- the
create_object
function returns a BaseObject that should be inserted in the active BaseDocument in order to let Cinema make good use of it. The method to look for is BaseDocument::InsertObject(); - upon inserting the objects in the scene an EventAdd() should be called in order to inform Cinema that the scene has changed and the events queue needs to be processed.
Something like the code below should work.
import c4d def create_object(x): position = c4d.Vector(x, 0, 0) a = c4d.BaseObject(c4d.Ocube) a.SetAbsPos(position) return a def main(): for i in range(1,2000,400): doc.InsertObject(create_object(i)) c4d.EventAdd()
That said I also recommend you for the future to:
- use the appropriate category for posting questions making good use of the Read Before Posting ;
- use the tagging system in order to improve our knowledge-base;
- use the Question & Answer functionality when posting questions.
Keep enjoying your discovery of Cinema 4D Python API and feel free to get back with further questions
Riccardo
- the
- the
create_object
Riccardo
- the
@r_gigante Thank for your kind and high-quality assistance!
it is such a great forum to study and learn
Hi Ilad, I've overlooked one thing here: my notes above are useful if you're running the code as a script in the Script Manager but if you're using a Python generator then you've to return an object in your code that contains all the different cubes and, in this case, the
EventAdd()
can be skipped.Something like this should work:
import c4d def create_object(x): position = c4d.Vector(x, 0, 0) a = c4d.BaseObject(c4d.Ocube) a.SetAbsPos(position) return a def main(): mynull = c4d.BaseObject(c4d.Onull) for i in range(1,2000,400): create_object(i).InsertUnder(mynull) return mynull
Best, Riccardo
@r_gigante
Thank for your professional help! I am so grateful for your commitment!
