controlled rendering programmatically
Hi there,
I'm wanting to render frames but would like to control the step dynamically. Sometimes rendering groups of frames than a gap then groups etc.
I can manage the logic of frame steps/groups but wondering if there is a command exposed to python to render a frame(s)?Also would this be better suited as a bash command process to run instead? Either way works for me but at the moment i cant find info on rendering programatically in c4d using any of these approaches.
Hello and thanks for the question,
First, for your next threads, please help us keeping things organised and clean. I know it's not your priority but it really simplify our work here.
- Q&A New Functionality.
- How to Post Questions especially the tagging part.
I've added the tags and marked this thread as a question so when you considered it as solved, please change the state :)
Regarding your question :
First, just to be sure you know about it, I would like to point you to the Render Queue where you can save your document with different render settings and choose them in the render queue dialog box. There's some possibilities there, even more with the take system.
Another possibilities to render document is to use the CommandLine where you can specify the frame you want to render as an argument. As you said using a bash script.
If you really want to control the render with python you can use the function RenderDocument witch will render the document to a bitmap and you can save the bitmap.
Manuel
hi,
without any further feedback, this thread will be considered as solve tomorrow.
Manuel
