GvNode parameters
I'd like to retrieve parameter information from Redshift Shader nodes.
So far I've gota BaseContainer and then accessed IDs and values with
GvNode.GetIndexId()
andGvNode.Get DataId()
The returned IDs are numbers e.g
10047
. How can I retrieve it's corresponding variable name e.gc4d.REDSHIFT_SHADER_MATERIAL_SHADOW_OPACITY
How can I retrieve further information about the parameter (It's Description?) to find it's default value, min/max values, label etc?
Thanks
Hello and thanks for the question,
First, for your next threads, please help us keeping things organised and clean. I know it's not your priority but it really simplify our work here.
- Q&A New Functionality.
- How to Post Questions especially the tagging part.
I've added the tags and marked this thread as a question so when you considered it as solved, please change the state :)
Thanks to @m_adam you can have a look at this github repository where you will find some useful information.
Let's answer the second question first because that maybe answer the first.
Once you have yourGvNode
you can retrieve the description of that node usingdesc = node.GetDescription(c4d.DESCFLAGS_DESC_NONE) for bc, paramid, groupid in desc: print bc[c4d.DESC_DEFAULT], bc[c4d.DESC_NAME], bc[c4d.DESC_IDENT], paramid, groupid
In the BaseContainer you can have information using DESC_xxxx ids
Sometimes it can be strange to retrieve the min/max value (it's often the min max value of the data type, so you have to use DESC_MINSLIDER)
DESC_IDENT, DESC_IDENT_ORIGIN can be interesting to answer your question 1 because it stores the resource identifier.
Another trick can be to retrieve all Symbol that have REDSHIFT in his name with something like this
rsSym = filter(lambda x: "REDSHIFT" in x , dir(c4d)) print rsSym
Manuel
@m_magalhaes Thank you, this is very helpful and does what I was looking for!
I can't seem to find GetDescription() in the API docs for GvNode or BaseList2D. Would there be a reason for this?
it's coming from C4DAtom
I've sent an email to Redshift to ask them if we can be sure that every Symbol have "redshift" in the name.
I'll come back if i have more information.Remember to mark this thread as solved once you are sure it's solved :)
Manuel
hello,
I've got some feedback,
You can't rely on the fact that all resource name contain Redshift. (most but not all).
As Some parts are generated dynamically this could break your tools.May I ask you what are you trying to implement ?
Manuel
