Hi! With the project tool, is it possible to specify visual studio-specific options beyond the options outlined here in the docs: https://developers.maxon.net/docs/Cinema4DCPPSDK/html/page_maxonapi_projecttool.html#page_maxonapi_projecttool_definition_win ?
Specifically, I would like to set the /DELAYLOAD linker option in my project from the projecttool. Is this possible?
Thanks /Filip
hello,
First, for your next threads, please help us keeping things organised and clean. I know it's not your priority but it really simplify our work here.
I've marked this thread as a question so when you considered it as solved, please change the state
About you question :
In the page you linked (i'm not blaming you i didn't saw it neither) there's the option AdditionalLinkOptions
something like this should work :
AdditionalLinkOptions=/DELAYLOAD:"mydll.dll"
It will be added to your linker properties "Configuration Properties-> Linker ->All Options->Additional Options"
Let me know if this solve your issue.
Cheers Manuel
Thanks, I'll try that!
Regarding the "Ask as a question", have you considered making this the deafult when creating new threads? I would assume most new threads are indeed questions, and it's easy to forget checking this option.
Actually, this does not seem to solve my problem. The option gets added under
just as you said, but I would need to modify
"Configuration Properties-> Linker ->All Options->Delay Loaded DLLs".
Is this possible from the project tool? This is for a public open source software, so I would really like to make the build process as streamlined as possible to aid external developers. Therefore, I would like to avoid manually changing the projects generated by the projecttool.
I've asked the devs, i'll be back as soon as I have information.
The command appears in Configuration Properties->linker->Command Line (the bottom box "Additional Options"). (I wonder why I didn't saw it xD : please don't answer that question ^^ )
It should be taken into account. Do you see any difference between adding your command there or in "Configuration Properties-> Linker ->All Options->Delay Loaded DLLs". ?
on windows AdditionalLinkOptions like so AdditionalLinkOptions=%(AdditionalOptions) /DELAYLOAD:"mydll.dll"
for OSX you can use OTHER_LDFLAGS
like so OTHER_LDFLAGS=-lazy_library;../pathToYourDylib
some warning on OSX :
Note however, that this delayed loading is deprecated in Xcode 11 on macOS 10.15 (and currently doesn't work anymore).
Thanks, I will check this again. I am marking this as solved for now.
/Filip
if you can give us feedback that would be awesome.
