I made a rig, and for some reason, it does not work well unless I scrub the timeline. It's as if the timeline gives an update to the scene. You can see an illustration of the problem here: https://www.dropbox.com/s/anlueipqy6t6rhw/c4d125_simulate_moving_timeline.mp4?dl=0
I'm not sure about this but I guess the term to do this redraw, correct me if I'm wrong. I checked the documentation but the redraw() method is only available under c4d.gui module.
redraw
redraw()
c4d.gui
Is there a way to simulate a scrub in the timeline or redraw on a document/scene level?
You may want to try ExecutePasses() - that command will animate the current frame of the document and therefore works like scrubbing the timeline.
@mp5gosu Not sure about the whole mechanics of the command but it works. Here is the code I used: doc.ExecutePasses(None, True, True,True,c4d.BUILDFLAGS_0)
hi @bentraje ,
Just to confirm @mp5gosu answer.
We can also point you to BaseDocument manual where you have some information about ExecutePasses
Cheers Manuel
