Input Event
On 05/04/2003 at 06:23, xxxxxxxx wrote:
Cinema 4D Version: 8.100
Platform: Windows ;
How can I retrieve a single input event outside a mouse movement in a tool plugin?
if (GetInputState(BFM_INPUT_KEYBOARD,KEY_SHIFT,res)) does only work when the mouse is moved. I need to know if the user pushes the Shift button only!
Thanks
On 11/04/2003 at 12:32, xxxxxxxx wrote:
Can't you use the the BFM_INPUT_MOUSE channel and look for the SHIFT qualifier in the result? (See another thread.)
On 11/04/2003 at 16:53, xxxxxxxx wrote:
As I said, I don´t want a mouse movement for the detection. I just want to detect if the user pushes the SHIFT or ESC key without any mouse movement.
Any chance?
Thanks
On 13/04/2003 at 01:37, xxxxxxxx wrote:
Hi Samir,
The 'GetInputState()' tells you the current _state_ of the input, so it doesn't matter whether the mouse is moving or not. It's _not_ informing you of an event. I'm using the following code (provided by Mikael) to read shift and ctrl in a tool plugin, and it seems to work fine:GetInputState(BFM_INPUT_MOUSE,BFM_INPUT_MOUSELEFT, state); Bool bShift = (state.GetLong(BFM_INPUT_QUALIFIER) & QSHIFT) != 0; Bool bCtrl = (state.GetLong(BFM_INPUT_QUALIFIER) & QCTRL) != 0;
On 13/04/2003 at 01:43, xxxxxxxx wrote:
Just as a quick hack - I tried the following, and it does correctly echo the current state of the Ctrl,Shift keys to the console, whether you touch the mouse or not.
cheers - Steve
Bool bShift, bCtrl; while(1) { GetInputState(BFM_INPUT_MOUSE,BFM_INPUT_MOUSELEFT, state); bShift = (state.GetLong(BFM_INPUT_QUALIFIER) & QSHIFT) != 0; bCtrl = (state.GetLong(BFM_INPUT_QUALIFIER) & QCTRL) != 0; GePrint("shift: " + LongToString(bShift) + " ctrl: " +LongToString(bCtrl)); }
On 13/04/2003 at 02:26, xxxxxxxx wrote:
Sorry, that doesn´t work for me unless I use the mouse. I don´t want to use the mouse. No clicking, no moving, just simply the shift key. :\ I seem to forgot to say that I also don´t want it outside a mouseclick. Sorry, my fault. Thanks anyway, though the code was known...
Does anybody know?
On 13/04/2003 at 10:49, xxxxxxxx wrote:
Hmm, I'm a bit puzzled. The 'hack' code above works on my system without me touching the mouse - just the shift/ctrl keys...
On 13/04/2003 at 14:01, xxxxxxxx wrote:
maybe this works:
GetInputState(BFM_INPUT_KEYBOARD, 'A', inputdata);
qualifier=inputdata.GetLong(BFM_INPUT_QUALIFIER);
On 13/04/2003 at 14:58, xxxxxxxx wrote:
Hi Klaus,
thank you, I will try that tommorrow. One of those has to work I guess :)
@Steve: Thanks anyway for your help!
On 14/04/2003 at 13:07, xxxxxxxx wrote:
I am guessing the reason it does not work is because you are trying to do so within a plugin tool ( one of those cool widgets possibly? ). The issue here as that none of those functions are called unless the mouse moves.
darf
On 14/04/2003 at 15:30, xxxxxxxx wrote:
yes, it appears to be so. :( It doesn´t work for me.
Well, thanks anyway to all of you.
Best
Samir
