Is there a way to get/fetch a node from an existing xpresso tag? For instance, of all 5 existing math nodes, select a node with a particular name or a particular operation type (i.e. multiply as opposed to add).
In the documentation there is GetNode method but it is specific to port. Basically, what I am after is something like.
GetNode
obj = doc.SearchObject("obj") tag = obj.GetTag(c4d.Texpresso) nodemaster = tag.GetNodeMaster() # get/fetch a particular node in the list of nodes of nodemaster
Is this possible? Thank you for looking at my problem.
Hi @bentraje GvNode are standard BaseList2 that means you can iterate them as you can iterate object in the ObjectManager.
With that's said here is an example:
""" Copyright: MAXON Computer GmbH Author: Maxime Adam Description: - Loops through all nodes from the Xpresso Tag of the selected object. - Checks if it's a Math Node. Class/method highlighted: - c4d.modules.graphview.GvNodeMaster - c4d.modules.graphview.GvNode - GvNodeMaster.GetRoot() - GvNode.GetNext() / GvNode.GetUp() / GvNode.GetDown() - GvNode.GetOperatorID() Compatible: - Win / Mac - R13, R14, R15, R16, R17, R18, R19, R20 """ import c4d def iterateNodes(node): """ This function iterates over a BaseList2D, GvNode inherit from BaseList2D. :param node: GvNode to iterate. """ while node: nodeName = node.GetName() isMathNode = node.GetOperatorID() == c4d.ID_OPERATOR_MATH # If it's a math node and set to multiply, prints the node name if isMathNode: isMultiply = node[c4d.GV_MATH_FUNCTION_ID] == c4d.GV_MUL_NODE_FUNCTION if isMultiply: print "Name: {0}".format(node.GetName()) # If it's a group retrieves all inner GvNode. if node.IsGroupNode(): iterateNodes(node.GetDown()) node = node.GetNext() def main(): # Checks if selected object is valid if op is None: raise ValueError("op is none, please select one object.") # Retrieves the xpresso Tag xpressoTag = op.GetTag(c4d.Texpresso) if xpressoTag is None: raise ValueError("Make sure the selected object get an Xpresso Tag.") # Retrieves the node master gvNodeMaster = xpressoTag.GetNodeMaster() if gvNodeMaster is None: raise RuntimeError("Failed to retrieves the Node Master.") # Retrieves the Root node (the Main XGroup) that holds all others nodes gvRoot = gvNodeMaster.GetRoot() if gvRoot is None: raise RuntimeError("Failed to retrieves the Root Node.") # Iterates overs all nodes of this root node. iterateNodes(gvRoot) if __name__=='__main__': main()
Cheers, Maxime.
Thanks @m_adam. Works as expected. My bad, I was looking at the documentation hierarchy erroneously (i.e c4d > modules > graphview > GvNode)
Just a note: I think the if Multiply: line is supposed to be if isMultiply:.
if Multiply:
if isMultiply:
Thanks again. Have a great day ahead!
