Solved "Do something when a value is changed" in Python Node?
Is there a way to perform an action if a value is changed?
The logic would be something like this:
If new value != with the existing value:
     do something:
Here is the existing code (inside of a Python node in an Expresso)
    store_value = 0 # The value ranges from 0 or 1
    if Input1 != store_value:
        print "Something changed"
        store_value = Input1
        print "Nothing changed"
The problem is at next draw/redraw/refresh the store_value stays at zero even though the Input is already at 1. This means the store_value = Input1 is not working.
You can check the illustration file here:
https://www.dropbox.com/s/y5ujqcp6ziecos3/c4d123_do_something_if_something_is_chang.c4d?dl=0
Upon opening the file, you'll see in the console printing "Nothing Changed" repeatedly. Now if you change the user data. It prints "Something Changed" but then it continuously prints "Something is changed".
The result should be something like
Nothing Changed
# Changes user data
Something changed
# Back to
Nothing Changed
Nothing Changed
Is there a way around this? Thank you for looking at the problem
Hi sorry I overlooked your answers.
If you want to have something more consistent you should store it into the scene. So the things that make more sense is to store it into the basecontainer of the current GvNode. Like so
    if not c4d.threading.GeIsMainThread():
    bc = op.GetDataInstance()
    # Get an unique ID at https://plugincafe.maxon.net/c4dpluginid_cp
    store_value = bc[1000001]
        bc[1000001] = Input1
Hi @bentraje the way to go is to use a global variable. This will define a variable in the global space of the current node that will be frame independent and will live as long as the node itself live.
global store_value
store_value = 0
    global store_value
Hi @m_adam
Thanks for the response. I tried the code but I still get the same result.
Nothing changed first.
Something changed.
Then something changed all throughout.
You can see the revised file here:
https://www.dropbox.com/s/8e8gk0ptsksyztc/c4d123_do_something_if_something_is_chang_v1.2.c4d?dl=0
Sorry, I edited the code, the main issue is that you defined each time the new value to 0.
@m_adam
No worries. Thanks again for the reply!
Just one last thing:
Is there a way to save the store_value when closing and then reopening the file?
The current set-up is user_data value = 0.
When you change the value from 0 to 1. It works perfectly (i.e. prints something is changed)
However, when the set-up is the user_data value = 1 (the user changed it in the last session),
and change the value from 1 to 0, it prints "Nothing changed" where it should be "Something changed".
Not sure if this is possible since store_value=0 is hard coded. Or do you have any alternative to the set-up? I'm all ears! Thank you
