How ObjectData add PRIORITY and execute
hi,
i am confuse about how to add PRIORITY in ObjectData like Skin and Hair object ? show in basic tab?
and how to connect PRIORITY to ObjectData::Execute()? i try to use ObjectData::AddToExecute(), it work but not same as ExpressionTag, it will execute when i move cursor or other action, even execute after i closed objectplugin. it is strange. if any way execute ObjectData::Execute() like ExpressionTag do ?
hope your help!
Objects and tags are two different things, so I would not expect them to work similarly.
In the case of the Skin object, the priority parameter is simply added in the resource file. Take a look at the
ocaskin.res
file.GROUP Obaselist { SEPARATOR { LINE; } PRIORITY ID_CA_SKIN_OBJECT_PRIORITY { ANIM OFF; NOCAMERA; } }
Within
AddToExecution()
the value of that parameter is read, converted to EXECUTIONPRIORITY and used to set the priority value of PriorityList::Add().best wishes,
Sebastian
ocaskin.res
Within
AddToExecution()
Sebastian
@s_bach Thank you!
