On 02/04/2003 at 13:51, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.100 Platform: Mac OSX ; Language(s) : C++ ;
--------- Hello, I implemeted the source code found in this forum for a BitmapButton. The original res declaration for the button is in the res file ( BITMAPBUTTON PLUGIN_BUTTON {} ). Everything works fine except there is no event generated when the button is clicked on. I am checking using the following:
case MSG_DESCRIPTION_COMMAND: { DescriptionCommand *dc = ( DescriptionCommand * ) data; if ( dc->id[0].id == PLUGIN_BUTTON ) { GePrint( "Here We Are" ); // *** } }
This message is never sent unless I change the res file element to BUTTON instead of BITMAP_BUTTON. I think that I am not setting a seond image for the button may be an issue. The code I found only sets one image:
case MSG_DESCRIPTION_GETBITMAP: { DescriptionGetBitmap* dgb = static_cast < DescriptionGetBitmap * > ( data ); if ( dgb->id[0] == PLUGIN_BUTTON ) { AutoAlloc < BaseBitmap > bm; bm->Init( GeGetPluginPath() + Filename( "res" ) + Filename( "PLUGIN_BUTTON_UP.tif" ) ); dgb->bmp = bm.Release(); } }
Where and how should I set the second down image? Is it possible that is why there is not event generated?
Thanks!
bt
On 04/04/2003 at 01:24, xxxxxxxx wrote:
I would like to know that too : Trying to get teh Customdatatype and setting the image with SetImage() (no matter where) or even GetHeight does crash my cinema 4d immediately. P.S.: Would be highly appreciated if you could tell me if you find out darf. Thanks
On 04/04/2003 at 04:58, xxxxxxxx wrote:
You must set the "BITMAPBUTTON_BUTTON" flag in the settings. In the resource file this means "BITMAPBUTTON PLUGIN_BUTTON {BUTTON; }".
On 04/04/2003 at 05:05, xxxxxxxx wrote:
I did BITMAPBUTTON ID {BORDER; BUTTON;} But that doesn´t help setting a second image when the button is pressed down. : BitmapButtonCustomGui butt = (BitmapButtonCustomGui* )data->GetCustomDataType(id,CUSTOMGUI_BITMAPBUTTON); butt->SetImage(bm,TRUE); this code then crashes cinema 4D. Maybe I am doing it in the wrong function (tried in message,init)? Where do we have to set the second image?
