I have some code that identifies angles between faces that share an edge. I would like to build a list of all the edges that pass a certain criteria and then melt them all. How can I get the index of all those vertexes (I just have the two points that define each one), and select them to perform a melt command?
Hi @rui_mac, thanks for reaching out us.
With regard to your question I recommend to use:
Best, Riccardo
Thank you so much. I was thinging that I had to provide an edge index. Never thought that it would just require to select the points that define the edges. Great!!!
