Hello, there!
The following code works(Python Tag). Whenever I press the User Data button, the global position coordinates from the object(cube) get stored in three separate User Data fields. Great!
The issue rises whenever the input in those three fields gets done manually, via keyboard, which is something totally valid for my purposes. Console says "index out of depth", and I just can't figure out how to avoid going that deep with the "if" comparisons, I mean, my goal is to stop passing the "if" tests whenever the messages come from inputs other than the User Data button.
import c4d def message(msg_type, data): if msg_type == c4d.MSG_NOTIFY_EVENT: event_data = data['event_data'] if event_data['msg_id'] == c4d.MSG_DESCRIPTION_COMMAND: desc_id = event_data['msg_data']['id'] if desc_id[1].id != None: #Trying to avoid 'Index Out of Depth' console messages if desc_id[1].dtype == c4d.DTYPE_BUTTON: #Gets Driver Object Global Matrix and stores its Global Position o = doc.SearchObject("Drv") if o: m = o.GetMg() pos = m.off #Update Button Hit if desc_id[1].id == 1: op[c4d.ID_USERDATA,1][c4d.ID_USERDATA,2] = pos[0] op[c4d.ID_USERDATA,1][c4d.ID_USERDATA,4] = pos[1] op[c4d.ID_USERDATA,1][c4d.ID_USERDATA,3] = pos[2] c4d.EventAdd() else: return def main(): pass
Thanks for your Attention,
Leo
User Data Button test.c4d
This is the test .c4d file.
Once again, thanks for your time.
hello,
The error message make sense as you are trying to reach a level on the DescID that doesn't exist.
So to avoid that you can simply check the depth of the DescID using GetDepth() to check if it's superior to 1.
or
you can create a DescID that you know your button will have and simply compare equalisty
import c4d myButtonID = 1 myByttonDescID = c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA , c4d.DTYPE_SUBCONTAINER ,0), c4d.DescLevel(myButtonID, c4d.DTYPE_BUTTON,0)) def message(id, data): if id == c4d.MSG_NOTIFY_EVENT: event_data = data['event_data'] if event_data['msg_id'] == c4d.MSG_DESCRIPTION_COMMAND: desc_id = event_data['msg_data']['id'] #first solution check if the descid depth is more than one #if desc_id.GetDepth() > 1: #second solution, we compare the id with the descID we know our button will have. if desc_id == myByttonDescID: #Gets Driver Object Global Matrix and stores its Global Position o = doc.SearchObject("Drv") if o: m = o.GetMg() pos = m.off #Update Button Hit if desc_id[1].id == 1: op[c4d.ID_USERDATA,1][c4d.ID_USERDATA,2] = pos[0] op[c4d.ID_USERDATA,1][c4d.ID_USERDATA,4] = pos[1] op[c4d.ID_USERDATA,1][c4d.ID_USERDATA,3] = pos[2] c4d.EventAdd() else: return def main(): pass
and this will allow you to have several button.
Cheers Manuel
@m_magalhaes said in User Data button Python Tag r19 - avoid "index out of depth" console feedback:
Thanks a lot, Manuel! It's perfect now.
