On 29/03/2003 at 09:40, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.100 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Hi !
First: I am new to this forum. So hello eyerybody! Second: I am german. So, please, excuse wrong formulations!
I started to write a channel-shader. For its purpose, it needs information about the geometry of the object that it is assigned to. This should happen in the initRender() function. I don't know how to get this geometry-information. I would like to get a point-list and/or a polygon-list. And it should work for parametric objects as well. It would also be nice to get the polygons of the selection if the material is assigned to a selection but also all polygons of the object, if required. Any ideas? Thanks for every answer!
PS: feel free to answer in german if you are also german
On 31/03/2003 at 03:39, xxxxxxxx wrote:
Hi Christian, You might find this thread useful.
Cheers - Steve
On 31/03/2003 at 04:25, xxxxxxxx wrote:
Hi Steve!
Thank you for your answer, but this thread is related to c++, i am currently working with coffee. There are some parallels, there is also a volumeData, but there is no "op" in Shaders, only in expressinons. The other Problem is, i need all polygons in the initRender()-function since i want to precompute values and not for every pixel, but only the output()-function gives acces to the volumeData(). There must be a way, to get an array containig the polygons, in every part of the shader, i think.
Thanks for further Tips Christian
On 31/03/2003 at 05:14, xxxxxxxx wrote:
Ah, I didn't notice that you were using Coffee. I've not looked into these areas in Coffee, so I don't know if you can the info you need or not.
Be aware though, that the C++ interface has a lot more functionality than the Coffee interface. Also, if you are writing shaders then speed might well be an issue.
If you can, I'd strongly suggest going the C++ route.
In the meantime, I hope someone else can help you with the Coffee approach.
On 31/03/2003 at 06:28, xxxxxxxx wrote:
Thx Steve! I know c++ is better, but although i have coded in c++ before, i have some problems with the sdk. But i am trying to get into it. But in the meantime i wanted to realize some ideas in coffee.
CU
