Set texture image to file not full path
    On 04/04/2003 at 10:19, xxxxxxxx wrote:
    Do you mean spread the contents out so that they are not too packed together?
    If you use Groups, you can use GroupBorderSpace(...) to put some space between them.  Since GeDialog layouts are done internally and automatically (like Java), you have to give it all of the objects (Text, Buttons, Groups, etc) either in the CreateLayout() method or in a dialog resource file.
    I use Groups the same way I use JPanels in Java - to divide and conquer the dialog display space into regions and to spread things out for a more easily interpreted display for the user.
    Let me know if I understood your question correctly.
    Robert
    On 04/04/2003 at 10:31, xxxxxxxx wrote:
    Well yes os true...
    But is you look the reseditor...
    You set all groups to Scale Fit etc... button etc too...
    In the resEdit it work fine
    But in the SDK i dont fineout the command that do this
    I know is a C++ standard when i use MFC is no problem
    But here I dont see how it work :(
    Niki
    On 05/04/2003 at 08:48, xxxxxxxx wrote:
    Oh, I see.
    That's because it's called something else, of course. ;0)
    BFH_SCALEFIT
    Robert
    On 06/04/2003 at 12:16, xxxxxxxx wrote:
    O ok but how to use it ;-)
    Niki
    On 06/04/2003 at 12:35, xxxxxxxx wrote:
    Use it in the flags field for the resource or flags argument for the method:
    AddStaticText(4001,BFH_CENTER|BFV_CENTER,0,0,GeLoadString(ERROR_MEMORY_TEXT),BORDER_NONE);
    Check out "Dialog resource" in the Help files for using flags in a resource.
    Also check out "Description resource" for Groups, Layout Layouts, etc. for dialog resources.
    Hope that helps and let me know if you have any other Dialog questions! :)
    Robert
    On 06/04/2003 at 12:42, xxxxxxxx wrote:
    O ok but that I know is not what I'm Looking for
    Is after , that i Done is ResEdit and it work in it
    Is after in the plugins it self . how to : If a enlarge the Dialog with the mouse to make all in side enlarge too, same as is in the ResEdit
    Niki
    On 11/04/2003 at 00:47, xxxxxxxx wrote:
    Ok it work Now :o)
    I just add the BFH_SCALEFIT|BFV_SCALEFIT
    in the LoadResource of the Dlg
    Thanks
    Niki
