SOLVED Howto trigger CommandData::GetState()
I have a GeUserArea where items are drawn. User can select one or more of these items.
Next to this I have several actions, defined as CommandData derived plugins, which can each perform a specific action on the selected item(s). I am able to control the state of these CommandData icons, using GetState() to obtain information from my userarea and return the appropriate value to show the icon/menu-item enabled or disabled, checked or unchecked.
Which message is actually responsible for triggering the CommandData::GetState()?
As I need to trigger the GetState when an item is (de)selected in the userarea, so that the CommandData can check the userarea and decide to enable/disable the command.
Thanks
hello,
In this context you can use EventAdd()
Manuel
I'm not sure if you are creating a customDataType + customGUI or only a customGUI. I'm also not sure where you are storing your data. I'm afraid you are storing your data in your GeUserArea witch is not a good place to.
Your data should be stored in a BaseContainer. This BaseContainer can be stored in a tag, an object, the Document itself.
I can still try to point to the right direction :
You don't have to send a message to trigger directly the CommandData::GetState()
There's an example that could help you in the sdk //sdk/source/gui/customdata_customgui.cpp or you can see the file on github
You will see that the GeUserArea use SendParentMessage to tell the parent that something have changed.
BaseContainer m(BFM_ACTION);
m.SetInt32(BFM_ACTION_ID, GetId());
SendParentMessage(m);
The parent will catch this message and will send a message to its parent. (in the exemple, Bool
ExampleCustomGUIDots::Command(Int32 id, const BaseContainer &msg))
So at the end, Cinema4D will trigger what it need and GetState()
Let me know if it's not clear.
Manuel
@m_magalhaes
Sorry, I didn't explain well enough.
I have a CommandData derived plugin with a GeDialog. The only gadget of the dialog is a GeUserArea.
In the userarea I draw items, which the user can "select" by simply left-mouse-clicking in the bounding box of the item.
Next I have several other CommandData derived plugins.
These are used to activate actions on the selected items.
What I try to perform is to enable/disable these "action" depending on the selected item in the userarea.
If I implement the SendParentMessage in the userarea (on successful item selection), it triggers the GeDialog::Command, which then triggers its parent with another SendParentMessage. But the parent of the GeDialog is its CommandData, while I need to trigger the "action" CommandDatas instead, in order to update their state.
hello,
Manuel
I had noticed that the EVMSG_CHANGE was actually triggering the GetState of my CommandDatas, but I was wondering if a different approach was available.
Still, I am OK with the EventAdd() solution. Thanks.
