Copy link object
Hi.
I copied the object of link field in the virtual object with GetClone ().
However, if the type of the linked object is a generator type such as instance, it can not be displayed properly below the linked object on the object manager.
I checked past posts and found that they have priority issues.
But I do not know how to solve it.https://plugincafe.maxon.net/topic/6250/6615_clone-of-a-linked-object
Please let me know if anyone knows who you are.
Hi @anoano.
I will need more information.
I'm not sure in which context you are, when you sayvirtual object
I think you refer to be inside of a Generator and the GetVirtualObjects method isn't?Moreover, when you say a link, you refer to a LinkBox parameter, so the linked object can be anywhere and not necessary a Child of the current Generator, isn't?
Last stuff, please make sure to mark your topic as a question. I've done it for this time (don't worry you are new, no issue at all), see Q&A New Functionality.
Re: Copy link object
This is the code I wrote.
BaseObject *HyperINS::GetVirtualObjects(BaseObject *op, HierarchyHelp *hh) { BaseContainer* bc = op->GetDataInstance(); BaseObject* main = BaseObject::Alloc(Onull); if (!main) return nullptr; BaseObject *link= (BaseObject*)bc->GetLink(ID_LINK, hh->GetDocument()); if (!link) return main; AutoAlloc<AliasTrans> aliastrans; if (!aliastrans || !aliastrans->Init(hh->GetDocument())) return main; BaseObject* ref = static_cast<BaseObject*>(link->GetClone(COPYFLAGS::NONE, nullptr)); aliastrans->Translate(true); ref->InsertUnder(main); return main; }
It will not work at the manager's position.
Hi, the topic is now marked as solved, did you solve your issue?
The only workaround I was able to find is to make use of AddToExecution and define it to GENERATOR+1, here you retrieve and clone the cache of the linked object in a member variable of your instance, then in the next GVO you make use of this cache, but this has the application that you work always on a mesh that has been generated in a previous SceneExecution call, which may be an issue in case of animation.
