This is my code.BUTTON_SET and BUTTON_READ is button. I hope save data in tag just like python,but when i click BUTTON_READ after BUTTON_SET, it just print 0 , the default value.I guess i need to update message.So,what should I do? or just where did I go wrong? Hope your help!
Bool MyTestTagPlugin::Message(GeListNode *node, Int32 type, void *data) { if (type == MSG_DESCRIPTION_COMMAND) { DescriptionCommand* dc = (DescriptionCommand*)data; const Int32 id = dc->_descId[0].id; switch (id) { case BUTTON_SET: { BaseTag* tag = (BaseTag*)node; BaseContainer* bc = tag->GetDataInstance(); bc->SetInt32(ID_MyTestTagPlugin,10); return true; break; } case BUTTON_READ: { BaseTag* tag = (BaseTag*)node BaseContainer* bc = tag->GetDataInstance(); GePrint(maxon::ToString(bc->GetInt32(ID_MyTestTagPlugin), false)); return true; break; } } return true }
Hi Mike, thanks for reaching out us.
With regard to your question, I've had no issue in running something very similar to your code. Just one note: the ID you're using to store the value in the BaseContainer doesn't have to coincide with the one you're using to register your plugin, is this the case?
On my side I have:
// cast to BaseTag and check BaseTag* customTag = static_cast<BaseTag*>(node); if (!customTag) return false; // retrieve the associated BaseContainer and checl BaseContainer* customTagBC = customTag->GetDataInstance(); if (!customTagBC) return false; // switch on message type switch (type) { // Description Command case MSG_DESCRIPTION_COMMAND: { DescriptionCommand* const dc = (DescriptionCommand*)data; if (!dc) return false; // check the descId and act consequently if (dc->_descId[0].id == T_PC11485_BUTTON_SET) { Int32 currentVal = customTagBC->GetInt32(T_PC11485_VALUE); customTagBC->SetInt32(T_PC11485_VALUE, currentVal + 1); } if (dc->_descId[0].id == T_PC11485_BUTTON_GET) { ApplicationOutput("Value: @", customTagBC->GetInt32(T_PC11485_VALUE)); } break; } }
for T_PC_11485.h
T_PC_11485.h
#ifndef T_PC_11485_H__ #define T_PC_11485_H__ enum { T_PC11485_BUTTON_SET = 1000, T_PC11485_BUTTON_GET, T_PC11485_VALUE }; #endif // T_PC_11485_H__
and for T_PC_11485.res
T_PC_11485.res
CONTAINER T_PC11485 { NAME T_PC11485; INCLUDE Tbase; GROUP ID_TAGPROPERTIES { BUTTON T_PC11485_BUTTON_SET {} BUTTON T_PC11485_BUTTON_GET {} } }
Hope this helps, Riccardo
HyperFile is very useful,cinema4dsdk:objectdata_hyperfile help me implement the function,but i also want to Know how to save data in nodedata just like python?
@r_gigante Oh!Thank you!The plug-in ID is the reason for the problem,use another shorter number and everything is ok.
Thank your for your help!
